better than stock
Old Oct 21, 2012
Sherlock's Avatar
Sherlock is an unknown quantity at this point
Question better than stock
I am looking into getting better suspension on my civic 2001. What I want is a bit of smoother ride. I love in colorado and the roads here are pretty much ****. I want something that when I go over a small divet in the road it doesnt feel like I just hit a manhole without a cover. I want it to be a little looser bound and rebound. I will be tuning this car later for racing but for now I want it as a dailer driver. Any brands or maybe even a direct swap from an acura of some sort. Just let me know thanks
Old Oct 21, 2012
sl33pyriceboi's Avatar
Re: better than stock
You obviously don't want to go too low then.
If you want a strut and spring combo, look into tokico blues struts paired with tein H.techs. That will give you a very light drop but will increase your smoothness even further.
If you want coilovers I would suggest getting tein basics. They are ultra soft for a coilovers option.
Old Oct 21, 2012
Sherlock's Avatar
Smile Re: better than stock
So I should stay with the stock springs and put Tokiko shocks on it. Sounds awesome.
Old Oct 21, 2012
It is possible for you to keep your stock Springs and just upgrade your struts. That would provide a little bit better of a ride.
Old Oct 21, 2012
Sherlock's Avatar
Thanks for the info man. I did look those shocks up, with the whole kit with springs and all its only like 550$
Old Oct 21, 2012
any amount of lowering will be rougher than the stock setup.
Old Oct 22, 2012
lowlife9's Avatar
yeah stock is going to be the most comfortable lowering springs are stiffer.
Old Oct 22, 2012
wwith the exception of Htechs.
when i had them on my accord with tokico blues.... oh man they were like riding on air.
Old Oct 22, 2012
if i am not mistaken, tokiko blues only with stock sprigns gets stiffer ride?
stiffer springs would counter the shock stiffness and actually control the shocks better, ending up in smoother ride, whenh they do work in conjunction. I am afraid i do not know which combination would be best fit, though. I only had one setup non-stock so far.
Old Oct 23, 2012
i know members running only tokicos on stock springs said the ride was much firmer. they are rated for lowered cars so the valving is different. which means harsh ride and a 4x4 look.
Old Oct 23, 2012
its not that bad...
but hence i said run it with tein Htechs
geforce789
Aug 19, 2015 06:17 AM
Misfit2613
Jul 30, 2015 09:49 AM
NoobyKid
Jul 13, 2015 07:53 AM
BootyDo
Jul 7, 2015 06:06 AM
7thgensurvivor
Jul 5, 2015 12:17 PM
