Problems Re-attaching tie rod to strut
Old Oct 14, 2012
emontgomery0227's Avatar
emontgomery0227 is an unknown quantity at this point
Hey, what's up? I need some advice on how to re-attach my tie-rod end to my strut assembly. The screw on the tie-rod end, the threading is stripped and when I tried to re-attach the nut it just keeps spinning. I tried using needle nosed vice grips to keep it from moving; didn't work. Someone suggested I use anti-seize and jack up the end of the tie-rod just enough to keep it from moving which I think would work if my jack went that high lol
My next plan is trying some anti-seize and use a c-clamp, I just don't want to destroy the end of the tie-rod...
any other suggestions?
Old Oct 14, 2012
BlueEM2's Avatar
Whachya lookin at?
Re: Problems Re-attaching tie rod to strut
The jack up method is the best method. Find a piece of wood to stick under the jack so you can get enough height.
Old Oct 14, 2012
YOU ARE A DANGER TO YOURSELF, YOUR PASSENGERS, AND EVERYONE AROUND YOU ON THE ROADS.
DO IT RIGHT.
REPLACE IT.
END OF STORY.
MY CAPS LOCK IS NOT BROKEN.
Threads stripped on the stud where the cotter pin goes through?
Junk it before you kill someone.
ALSO, if this has been run loose for a while, it has PROBABLY beat the taper out of the steering arm on the strut (or knuckle on other cars)
Tapered fits must match properly, or they can't wedge themselves together the way it was intended. They will come loose repeatedly or never fit tight in the first place.
Old Oct 14, 2012
BlueEM2's Avatar
Whachya lookin at?
Oops I missed that it was stripped.. Yes definitely replace.
Old Oct 14, 2012
maybe I shouldn't have said stripped, there is plenty of threading on it all the way up, its just not catching. the threading is definitely not quite right. but getting the tie rod out in the first place was an issue because it was properly mounted. it wasn't loose and there isn't any excessive play.
damn... didn't want to have to get into that tho...
thanks.
Old Oct 14, 2012
BlueEM2's Avatar
Whachya lookin at?
It's not an expensive part. Might as well replace it now while your here.
Old Oct 14, 2012
true story.
thanks
bravo79
Suspension
18
Feb 10, 2022 09:52 PM
mrohitredd
May 28, 2015 10:03 AM
tomg
May 21, 2015 07:05 AM
pheaton
May 4, 2015 08:26 PM
El_Spic
Apr 23, 2015 03:14 PM
