DC5 Sway Bar, Clunking Noise
Old Jun 1, 2012
krudmuphin's Avatar
I've had a 21mm DC5 sway bar installed on my EM2 for about 5 days now, but ever since the install, there's been a disturbing clunk or knocking sound coming from the rear suspension and I'm not sure why. From the inside of the car, it sounds like the noise is on the passenger side, but outside the car it sounds like the driver's side.
I have double checked and ensured that all the bolts were completely tightened up, both the brackets and end links. I sprayed WD40 in the sway bar bushings too. I even checked other things like my wheel lugnuts and coilovers to make sure they weren't making the noise. On top of all this, I fabbed a foam guard for the sway bar so the exhaust does not rattle on it, but still there is a loud clunking noise.
It only occurs at slow speed and usually when the wheels are moving up and down independent of each other. This leads me to believe that it's actually the torsion of the new bar making twisting a popping sounds. Is that all it is and I shouldn't be worried about it?
If anyone's had a similar issue, I'd love to hear it and get all the help I can. I doubt the noise is anything serious, but it doesn't sound too pretty...
Thanks
Old Jun 1, 2012
MindBomber's Avatar
Live for the Twisties
Re: DC5 Sway Bar, Clunking Noise
Hard to say, it's possible the endlinks or bushings are bad. I would jack up the rear of the car and start moving parts by hand to try and pin point the source, there are many things that could cause this.
Old Jun 1, 2012
lazlong's Avatar
It shouldn't pop. I surmise the extra stiffness is causing an already worn part to wear more.
Especially check every bushing in the rear end. There's also a top mount bushing in the strut assembly.
Old Jun 1, 2012
back what said above 2 posts
Old Jun 2, 2012
krudmuphin's Avatar
Could parts like end links and OEM bushings seriously be worn at only 55k miles? Also I've grabbed and shaken every component pretty forcefully but I can't seem to generate the noise by hand. Bouncing the rear end of the car won't do it either. Should I try tapping parts with a mallet?
I've heard rumors that EM2s make lots of confusing rattles and clunks when you start modifying them. Now I see exactly what they mean
Old Jun 2, 2012
regrease the bushings?
Old Jun 2, 2012
MiStAmOo's Avatar
MiStAmOo is on a distinguished road
I had this same clunking with no way of replicating it from pushing down on the car. I changed out both endlinks and the bushing and the noise was gone.
Old Jun 3, 2012
krudmuphin's Avatar
Spent the whole afternoon in the garage trying to locate the noise again. This time however, I found the problem rather quickly. It turns out that the sway bar wasn't perfectly centered between the right and left sides of the car. So one of the endlinks was severely angled while the other was straight up. I tapped the bar to the left a bit more and when I tightened it all up again, the noise was gone. I think it was putting some unnecessary stress on the passenger side endlink and that was somehow causing the sound.
The bar was centered when I installed it, but one of the brackets was a bit loose, causing it to shift.
Old Jun 4, 2012
MindBomber's Avatar
Good work
pizzahutcombo
Suspension
Jul 13, 2021 09:41 PM
juror
Suspension DIY
Jul 30, 2019 03:28 AM
muniorbust
33
Aug 31, 2015 08:59 PM
protoCall7
Bolt-on Engine Performance
Jul 26, 2015 07:41 PM
06Si_Girl
Jul 12, 2015 12:08 PM
