Quick! Need help
Old May 23, 2012
mikereynolds9's Avatar
mikereynolds9 is an unknown quantity at this point
Quick! Need help
Today I was working on installing my progress coilovers. Everything was going well and when I went to torque down the upper strut bolt. The one in the middle to its spec I couldn't get it to tighten any at all. There's a huge gap between the bolt and the top of the coilover. Here I have attached pics. I followed the directions they gave me and everything seemed perfect when I was installing it. Has anyone seen anything like this when they did their coilovers?
Here are some pics.*
Passenger side
Drivers side
Old May 23, 2012
Re: Quick! Need help
Use a socket and ratchet to hold the shaft still, and use a wrench to tighten the nut.
The nut is a locknut, so it probably has a nylon insert...it will be tight all the way down.
Or get a 1/2" drive impact gun and see if the nut will zip down.
HTH
Old May 23, 2012
lowlife9's Avatar
what he said.
Old May 23, 2012
04 Honda Civic's Avatar
What are you using to tighten it?
Old May 23, 2012
Im using a socket on a torque wrench
Old May 23, 2012
TFMEX's Avatar
CO&CA
TFMEX is a jewel in the roughTFMEX is a jewel in the roughTFMEX is a jewel in the rough
your strut is spinning with the nut. you have to hold it still while tightening the nut. impact guns work well because they spin faster than the strut. when it gets to a certian point you can just crank it down
Old May 23, 2012
Very nice. Worked perfect. But now I can't get the rears in. The bottom hole here the single bolt goes in through the strut wont go in. I've tried everything to get it in and nothing. So I'm taking it to work today to grid it down a little and hopefully that'll help.
Old May 23, 2012
MindBomber's Avatar
Live for the Twisties
The bolt itself won't go in or the coilover itself, RSX coilovers are a bit wider and won't fit properly without shaving a bit of material off.
Old May 23, 2012
The coilovers I bought are made for my yr civic. But it is deffinetly wider. I'm about to trim them down and was wondering if I should do both sides to make it even or just do one side?
Old May 23, 2012
MindBomber's Avatar
Do both sides.
Old May 23, 2012
Do both sides.
Thanks! These forums have been a great help for me doing my first suspension upgrade.
Here's a teaser shot of what I have done so far. Just missing my rear struts and progress front sway bar.
Old May 24, 2012
rjones7755's Avatar
Im jealous...what size is the rear sway?
Old May 24, 2012
It's the progress 22mm rear sway bar. I also have the progress 27mm front sway. Just waiting on new end links to come in
Old May 25, 2012
TFMEX's Avatar
CO&CA
wow 27mm in the front.... I kept my stock one 15mm (i think on the 04 EX) to give me more control in the front. the bigger bar in the front causes more under-steer. Some remove the front bar all together.
I have a 19mm in the back and 15 in the front and noticed night and day from the stock bar set up.
Old May 26, 2012
Hmm idk I gave an ex and it already had a front and rear sway bar. But there do tiny looks like they wouldn't be worth a damn.
Anyways I have another question if anyone could help me out. So after I did everything I moved onto removing my front lca do I can put in my ES bushings in and while trying to remove the ball joint using every trick I could find and not able to get it out I tore up my ball joint. Now I have to replace my ball joint idk how I'm going to get it out so hopefully I can figure something out.
Anyways I was going through the ball joint DIYs and noticed That it have found two different torque specs for the two bolts in the front struts. One is in the "all the suspension info you need it says it has to be tightened down too like 115 ft lbs and in the ball joint DIY it says it's 72 ft lbs. So wich one is it? I'm really hoping the 115 ones because that's what I torqued then down too. Thanks guys.
Old May 26, 2012
TFMEX's Avatar
CO&CA
I'm not sure atm... I'm on my way to the dump. 115 should
Be fine as long as its not stripped which you would know. Its just gonna suck to remove it lol
Old May 26, 2012
Lol yaa that's exactly what I was thinking. Not too excited about having to remove it to do my ball joint now. I was just going to go with an oem ball joint but I see these extended ball joints is there any advantages of going that route.
Old May 28, 2012
efff you and efff you
Old May 28, 2012
MindBomber's Avatar
Extended ball joints correct compromised suspension geometry by moving the angle of the control arms back to level from a raised position; the raised position of the control arm is a result of lowering. The suspension will be more responsive when they are installed on a lowered car. They don't make a tremendous difference, however.
This is sort of turning into a build thread, do you want me to it to member rides and change the title?
Old May 28, 2012
Yes. Thanks mindbomber. I've been meaning to create one I just need some good shots of the outside of my car.
Tedverseti
Apr 23, 2020 01:45 PM
ricer_em2
May 11, 2016 08:09 PM
mnewcomb
Air Conditioning
Sep 26, 2015 11:02 PM
metalpres
Sep 23, 2015 05:22 AM
