Complete Newb needs schoolin'
Old Jan 20, 2012
masterguns's Avatar
masterguns is an unknown quantity at this point
I have an 02 coupe. It makes a clunking noise on turns and potholes. Do I likely need new struts or new shocks or both? I'm not sure what our cars have. I was thinking of getting the Tokico Shock & Spring kit (HPK309) but didn't want to get it to the mechanic and him say I need new struts as well and be out even more. I guess my question is what does an 02 coupe have stock? front/rear struts shocks or both? (BTW: I read the FAQ and didn't help)
Old Jan 20, 2012
MindBomber's Avatar
Live for the Twisties
Re: Complete Newb needs schoolin'
Front struts, rear shocks.
Old Jan 20, 2012
whatsaricer's Avatar
whatsaricer is an unknown quantity at this point
Edit: My bad, bomber beat me to it lol
"Suspension
MacPherson strut front suspension
Double wishbone rear suspension
Four-wheel independent suspension"
from http://www.edmunds.com/honda/civic/2...res-specs.html
as a heads up if your getting a clunking noise when turning(and that term can be used for many different noises) you may have a tie rod issue as well.
I would have your mechanic check everything out for you and then just get a quote and buy the parts yourself or something. Its not worth replacing the wrong parts, trust me.
Old Jan 20, 2012
masterguns's Avatar
Thanks guys, I'll definitely take your advice and have a guy look at it before buying anything.
Old Jan 20, 2012
lowlife9's Avatar
could also be the lower ball joint or the control arm bushings both can be visually inspected yourself. the control arm bushings are notorious for going bad on these cars.
Old Jan 20, 2012
naturally if the struts/shocks are bad, it's a good time to do them, or else yer gonna need another alignment soon down the road.
Old Jan 20, 2012
Speed9117's Avatar
Speed9117 will become famous soon enough
I second lowlife. I had a clunking noise and it ended up being the front compliance bushings (front LCA) if that's the case go with some Energy Suspension Polyurethane bushings. They're pretty cheap and high quality stuff.
Scout1
Oct 5, 2015 01:33 PM
Mad Dog Tannen
Sep 12, 2015 12:48 AM
Wiggles
Sep 8, 2015 05:05 PM
Josh 1973
Sep 7, 2015 10:10 AM
rainman15
Sep 6, 2015 11:10 AM
