Any advice for 05 vp?
Old Dec 23, 2011
Hardcoresteve's Avatar
Hardcoresteve is an unknown quantity at this point
Ok so im rounding 120,000 miles and my suspension is shot. I was originally going to go with the progress sway bars, but I see too many issues with my custom exhaust being in the way. Honestly I was content with the handling from stock.
My plan as of now is the neuspeed front strut bar and generic rear upper brace, some new oem struts, and some control arm bushings, tie rod ends n thats it. I havent seen any suggestions for oem struts on the site if anyone has any. And any opinions on the polyeurothane motor mounts?
Old Dec 23, 2011
MindBomber's Avatar
Live for the Twisties
Re: Any advice for 05 vp?
Poly motor mounts are the best purchase I've made for my entire car.
Old Dec 23, 2011
does the RSX fit around? don't forget the progress kit for endlinks
great
you looking for the bling factor only? because there will be not much to gain if any
tokiko blues, as many times mentioned
Old Dec 23, 2011
Thats good to hear. I was looking at the ones on corsport.com probably the red(60a)
Old Dec 23, 2011
great
Not sure what swaybar will fit. Its a vp, so when I did the a2 swap I used the a2 mani and the exhaust was all custom made 2.25" downpipe and all. Maybe ill post a pic of the front?rear where the swaybars go.
And no if the rear tower bar wont help ill skip it.
And ill check out the tokiko blues. I saw them mentioned, but I thought they were for drop springs. I just want stock ride height since the roads around here are rough+alot of speedbumps. Thanks for the input.
Tyler93
Mar 20, 2016 09:03 PM
2002ExCivic
22
Sep 28, 2015 08:29 AM
PunX
Sep 23, 2015 10:45 PM
sf3r8z
Sep 23, 2015 03:26 PM
bhollie
Sep 22, 2015 11:08 PM
