My car squeaks when turning?
Old Feb 19, 2011
dipstyck's Avatar
dipstyck is an unknown quantity at this point
Question My car squeaks when turning?
Hi, I am new to the forums. I have a 2002 civic which I recently replaced both the shocks and the struts on this car. I left the shop and the car still squeaks when it turns. It use to make a popping sound like (POP) when I went over bumps and drove the car quickly. My car has 72000 miles on it. In good condition and I don't drive it often daily maybe 3 miles to work and home. I don't know what else could be causing this squeaking noise. Any advise to bring to my mechanics attention? Any help would be greatly appreciated.
Old Feb 19, 2011
MindBomber's Avatar
Live for the Twisties
Re: My car squeaks when turning?
If the car makes the popping sounds when going over bumps then it means your LCA bushings are toast, the part itself is cheap but also fundamentally defective. I'd suggest upgrading to poly bushings, although it will make the ride a bit rougher they'll last the life of the car. The squaking likely is your strut bearings, they just need to be taken out and regreased. The labour on the bushings should be around $200, the labour on the bearings should be free since your mechanic neglected that originally.
Old Feb 19, 2011
combinatorix's Avatar
combinatorix has a spectacular aura aboutcombinatorix has a spectacular aura aboutcombinatorix has a spectacular aura about
Does it sound like more like a mechanical squeak or a high-pitched squeal that lasts for a second after you finish turning?
The popping sounds like bad bushings. If its squealing while turning, it could be your power steering is having issues.
Old Feb 20, 2011
sl33pyriceboi's Avatar
its your power steering belt or AC compressor belt. its loose.
Old Feb 20, 2011
prist's Avatar
prist is an unknown quantity at this point
Check the upper and lower ball joints
Old Feb 20, 2011
huhn, no. a 7th gen is strut - no upper ball joint
Old Feb 20, 2011
dipstyck's Avatar
Thanks everyone for answering me, it turns out to be my arms on the car, they are worn and the rubber is gone, they are replacing it tomorrow for FREE for their mess up. I knew I wasn't crazy hearing this sound, Dumb question what is LCA? I am new to the car lingo.
Old Feb 20, 2011
MelJ's Avatar
Trance Addict
LCA=Lower control arm. Honda's old suspension, double-wishbone, had two arms. A lower and upper(duh). This provided better handling, but I guess for cost reasons they went to the McPherson Strut setup which only features one control arm(lower) and one ball joint(which is what sdaidoji is talking about).
Old Feb 20, 2011
dipstyck's Avatar
this is a link explaining what happened to my car
http://www.car-stuff.com/hondacontrolarm.htm
Thank you all for your help it is so appreciated!!!!!!!!!!!!!!!!
Old Feb 20, 2011
MelJ's Avatar
Trance Addict
That's what these guys are here for. Glad to hear everything got sorted out.
Old Feb 20, 2011
dipstyck's Avatar
thanks for the great advice, prosteer is what i am putting on the car...I am so happy and excited at the same time...Thank you everyone...I thought I was crazy but I guess this is a common problem with Civic's. I love my car so much...I hope that this will do the trick
Dipstyck
Old Feb 21, 2011
unfortunately for all of us, the LCA bushings are really the case you mention...
glad your case is solved
Old Feb 22, 2011
MartinL's Avatar
MartinL will become famous soon enoughMartinL will become famous soon enough
I had the popping noise over bumbs and swapped out the bushing..stopped that noise. I'm happy because to get home I have to drive through a school zone that is comprised of 7 speed bumps!!
Old Feb 22, 2011
did all the students come to the windows to check what was that noise?
Old Feb 23, 2011
MartinL's Avatar
They came to help me find my lost candy puppy
haha
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
mikemc422
Aug 9, 2018 05:41 PM
ghondavic
Transmission
Apr 12, 2017 09:37 PM
McD
Apr 22, 2015 05:28 PM
GH04si
Apr 15, 2015 08:13 PM
