camber kit help
Old Sep 26, 2010
ursalog's Avatar
ursalog is an unknown quantity at this point
camber kit help
i want to raise the ride height of my car a few inches for winter and i read in another post i could use a camber kit i have a 2001 honda 2 door ex could i use these cambers to lift it? or are they lowering only http://www.procivic.com/pages-produc...799/index.html
http://www.procivic.com/pages-produc...673/index.html
Old Sep 26, 2010
sam68's Avatar
sam68 is an unknown quantity at this point
Re: camber kit help
Springs/shocks or Coilovers lower or raise a car. Camber kits fix camber.
Old Sep 26, 2010
Re: camber kit help
yea... camber kit only adjusts the angle at which your tires lean. They're used to correct your tire leaning inward at the top/outward at the bottom, or negative camber, as result from lowerin a car.
and like mentioned above, you can only raise/lower your car by either swapping out springs/struts or utilizing the adjustability of coilovers.
Old Sep 26, 2010
Re: camber kit help
or you could just use taller tires and wheels, but you will have the speedometer and tachometer thrown off.
Dave Brabant
20
Oct 6, 2015 12:44 AM
Tedverseti
Sep 29, 2015 05:41 PM
Hutch1051
Sep 29, 2015 09:20 AM
anubis62
Sep 27, 2015 12:56 AM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
