Just did my suspension, front right clunking noise?
Old Aug 24, 2010
Bruce Law's Avatar
Bruce Law is an unknown quantity at this point
Just put in some neuspeed race springs and did a test drive. I hear a clunking noise in front right passenger side, almost like rapid fire very noticeable at low speed but also does it at high speed. Sounds like my springs, i'm pretty sure i did everything right, grease the upper mount, line it up with arrows. And also my rear is lower than my front which is odd because the front are suppose to be lower than the rear. Front has two fingers and rear has no gap. Other than that handles great on curves big improvement. Can anybody help me out with info on the clunking noise?
Old Aug 24, 2010
lowlife9's Avatar
Re: Just did my suspension, front right clunking noise?
did you possibly put the rear springs on the front and vice versa ?
Old Aug 24, 2010
lazlong's Avatar
Sounds like strut mounts but, look over every joint in the suspension.
Old Aug 24, 2010
02civicsi02's Avatar
Low and slow!
Sounds like the top strut mounts to me to. Have you tightened it down good. And it could also be from not sitting the coil in the strut good.
Old Aug 24, 2010
Bruce Law's Avatar
Yea i torque everything to factory specs, but i did add a camber kit also. No i did not put the springs in reverse but i did put the rear springs in upside down ( the lettering is upside down). Think i'm just gonna redo that side again maybe it will fix it but thanks for the help guys.
Old Aug 24, 2010
lowlife9's Avatar
does it make the noise when your driving straight or when you turn the wheel ??
Old Aug 24, 2010
lazlong's Avatar
When you change anything in the suspension it puts more stress on the parts you didn't change. Therefore it could be anywhere in your suspension.
Old Aug 25, 2010
Bruce Law's Avatar
Did some more testing today and it just makes it going straight not on turns. Pretty noticeable at around 20-30 mph, when i engage the clutch from 2nd to 3rd. If i take off fast no noise but if i cruise slowly it it starts popping.
Old Aug 26, 2010
Bruce Law's Avatar
Haha yes finally got my problems fix. I redid my back springs adjusted the perch level on my koni shocks to top position and ride is one finger gap all around. Also redid my front right springs and strut, torque everything down to spec and only difference i did this time was grease my upper mount with white lithium grease and no more clunking noise. Sweet finally done it was a bitch in my hot *** garage about a 100 degrees but save myself money in the long run.
Old Aug 26, 2010
lazlong's Avatar
"I AM the law!"
Old Aug 30, 2010
Pongo08's Avatar
Pongo08 is an unknown quantity at this point
I didnt have this same problem, but i did have a popping noise after i changed my springs. mostly only when turning though. after a little playing around i found out it was the metal plate that snaps onto the top of the spring. its got an angle and you have to fit it up right with the angle where it contacts the car.
bravo79
Suspension
18
Feb 10, 2022 09:52 PM
edspyhill09
Jun 12, 2016 02:45 PM
oneheadlight
Apr 29, 2015 11:30 PM
bsmiley
Apr 27, 2015 01:27 PM
GH04si
Apr 15, 2015 08:13 PM
