Lowering Springs
Old Aug 26, 2010
MOCivic's Avatar
MOCivic is an unknown quantity at this point
Lowering Springs
My local custom shop has Tein S-Tech springs. He said he will sell the springs and install them for 250$. Is this a good deal?
Also, he said that its not a big enough drop to need a camber kit, i find this hard to believe. Is this true?
My car is an EM2 01 coupe ex with 17in Konig rims.
Old Aug 27, 2010
20_CiViC_02's Avatar
20_CiViC_02 is an unknown quantity at this point
Re: Lowering Springs
Sounds like a good deal. How much are you planning on dropping it?
And what size are your tires?
Old Aug 27, 2010
I think $181.30 with free shipping sounds better than $250 +tax
http://thmotorsports.com/tein/tein_s...0/i-35053.aspx
and I'd recommend a camber kit regardless..
Old Aug 27, 2010
Hoffman199's Avatar
Hoffman199 is an unknown quantity at this point
subscribing
Old Aug 27, 2010
Oh, and you can get away with using them on stock struts, but I'd recommend slapping the springs on a pair of tokico HP (blues) shocks. I ran for a year with s-techs on stock struts, but the ride quality got better once I installed the struts.
http://thmotorsports.com/Store/Produ...357&Make=HONDA
make sure you get the correct year (01-02 or 03-05). They changed the bottom bolt size between the years, one has a 14mm bolt, the other has a 16mm bolt.. I keep forgetting which is which. I'm sure someone will come on a post which one has which after reading this.
Old Aug 27, 2010
dezod's Avatar
7thgen Power Maker
Not that great!
http://www.dezod.com/pd_tein_stech_springscivic.cfm
I will throw in free shipping to you if you order from us.
Old Aug 27, 2010
dezod's Avatar
7thgen Power Maker
or
http://www.dezod.com/cat-shocks4.cfm
01-03 use a 14mm bolt and 03-05 use a 16mm bolt. There was an early production shift in 2003 between the two
Old Aug 27, 2010
dezod's Avatar
7thgen Power Maker
We are a Tein authorized dealer and Eddie there is WELL below MAP, which he does not have to obide by because he is NOT direct with Tein.
Also, to the OP, a camber is recommended for the rear for sure. The rears on these cars get real out of wack quick.
http://www.dezod.com/cat-camber.cfm
Old Aug 27, 2010
MOCivic's Avatar
hes charging 150 for the springs and 100 for install. i dont have the tools or the experiance to change that springs. Is this still a good deal?
Old Aug 27, 2010
like informed before, 183 free shipping from tein.
Old Aug 28, 2010
I hate living in Canada. All these places are like "free shipping", but usually that's only to the states, and even if it is to Canada, I have to pay duty and border taxes.
A $50 USD item ends up costing me well over $110 CDN.
Old Aug 28, 2010
sam68's Avatar
sam68 is an unknown quantity at this point
I hate shipping anything to Canada, cost and a bunch of paperwork to fill out really sucks.
Old Aug 28, 2010
crossfire's Avatar
crossfire is an unknown quantity at this point
$100 for install all 4 springs isn't that bad of a price. My local shop wanted to charge me $150 to install my springs but I decided to do them myself and turned out great. I just didn't like the fact that my rear struts were shot to $hit. Lol
Old Aug 30, 2010
grendel's Avatar
grendel has a spectacular aura aboutgrendel has a spectacular aura about
Guys, the price the shop quoted him includes installation. So, $250 for (assuming brand new) Teins, installed, warranted... IMHO that's a pretty damn sweet deal.
THIS THIS THIS. It seriously sucks.
Old Aug 30, 2010
only thing to look at is the condition of the springs.
they are 30 bucks less, plus the install.
So if you inspect the springs and they are good, go for it.
Old Sep 1, 2010
Originally Posted by Datern
Hi,Lowering Springs are designed to improve handling performance and the vehicle appearance, the aftermarket spring rates are stiffer compare to the most of the OEM factory springs. Installing the lower spring will increase corner grip and reducing body roll. While you purchase a set of spring, it is recommended to replace your factory shock absorber at once. The factory or aftermarket factory replacement shocks are not designed to support the stiffer lower springs. Once the shock failed, you might experience vehicle hopping and lose road traction. There are many different brand of lowering springs available in the market for you to choose from, you will first need to determine if you are using for street use or on the race track.
spam bot!
GolNat
Nov 27, 2018 03:32 PM
skeener51
Oct 1, 2015 05:56 PM
gilloz
Regular Maintenance
Oct 1, 2015 11:38 AM
jackoncruzpr
Sep 29, 2015 07:59 PM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
