My car bounces like a basket ball, suspension time! Help..
Old Sep 5, 2010
MindBomber's Avatar
Live for the Twisties
I have 128k kilometers on my 02 Si/Ex and I'm on totally original suspension.
I'm planning on ordering the following in the next couples days:
Tokico, front and rear struts.
OEM front strut mounts.
Energy Suspension, LCA bushings.
Moog, Ball joints.
I'm planning on repacking the bearings with fresh grease to avoid ordering new ones. I've heard about other guys replacing the tie rod ends and sway bar end links, but I wanted to confirm that you only need to replace those if the current ones are damaged?
Am I missing anything?
Also, are these jobs very difficult? The most intense DIY I've done is my brakes, so I'm a bit nervous...
Thanks in advance guys!
Old Sep 5, 2010
Re: My car bounces like a basket ball, suspension time! Help..
sounds good to me! the ES lca bushings are a shop install since you need a press to get em on. for suspension, see Mex's spring and shock diy. and the other ball joint diy. tie rod ends you will prolly rip the boots removing em.
Old Sep 5, 2010
MindBomber's Avatar
Is it possible to replace just the tie rod boot, or will I need to buy the whole thing?
Edit:
Energy Suspension makes replacement tie rod end boots that cost $3.89. I can only find them listed as fitting up to 2000 civics, but their website says that its fine as long as the tie rod is larger than the minimum dimensions; I'm going to buy a set as an experiment.
http://www.energysuspensionparts.com...p?prod=9.13101
Old Sep 5, 2010
last time i checked i did not find the boots for our car so i replaced the whole thing.
bsmiley
Apr 27, 2015 01:27 PM
El_Spic
Apr 23, 2015 03:14 PM
GH04si
Apr 15, 2015 08:13 PM
SleepyT
Nov 1, 2001 04:59 AM
