Megan Coilovers+Camber kit?
Old Sep 2, 2010
iallan's Avatar
iallan is an unknown quantity at this point
First let me say that yes i did use the search function. No one provided a solid answer about this and i need to know asap because i have an oppurtunity to buy some used Megan coilovers for $500. DO I NEED A CAMBER KIT IF I GET THESE?? Megan claims that the pillow ball upper mounts correct bad camber. Can i rely on that?
Sorry if these seems at all noobish. haha.
Old Sep 2, 2010
Muirsy's Avatar
Muirsy is a jewel in the roughMuirsy is a jewel in the roughMuirsy is a jewel in the roughMuirsy is a jewel in the rough
Re: Megan Coilovers+Camber kit?
i would get the camber kit just to be safe especially if you want to go low
Old Sep 3, 2010
Foffie's Avatar
Im a Senior Member. Take that Noobs!!
Foffie has a spectacular aura aboutFoffie has a spectacular aura about
yes you need a camber kit camber is not adjustable from the factory and you WILL have negative camber if you lower you civic
Old Sep 3, 2010
02civicsi02's Avatar
Low and slow!
Yes you will need a camber kit.
Old Sep 3, 2010
Afrodeziak's Avatar
Afrodeziak is an unknown quantity at this point
The pillowball tophats in the front allow you to adjust camber.
In the rear you use a camber kit. I have this exact same set-up.
Old Sep 3, 2010
iallan's Avatar
Thanks for everyone's input, i appreciate it!
Old Sep 3, 2010
agree. if they have the top hats with slots to slide the top, they are camber adjustment.
rears you will need a kit. (they are actually more important than the fronts...)
Old Sep 7, 2010
iallan's Avatar
Just an update, i picked them up this weekend, got the whole set for $400. Just had to touch up the springs with some tremclad rust paint or something because the finish is flaking off and there is some surface rust. Also need to pick up a camber kit now. I was thinking the matching Megan. Thanks again for everyones input!
Mad Dog Tannen
Oct 19, 2016 08:12 PM
Tedverseti
Sep 29, 2015 05:41 PM
Hutch1051
Sep 29, 2015 09:20 AM
anubis62
Sep 27, 2015 12:56 AM
beanhead
Sep 24, 2015 12:04 PM
