New suspension installed...Question
Old May 23, 2010
FerstlerSlim's Avatar
FerstlerSlim has a little shameless behaviour in the past
I installed Tokico HTS shocks and struts with Vogtland springs 1.3" drop. (2004 EX, 2dr) Installation seemed pretty straight forward but i have a clunking sound coming from the front struts, when i hit sharp bumps or pot holes. I put new strut bearings in and sway bar end links. There was a slight clunk in the rear before the install and i still have it after the install. I shortened the rear bump stops about an inch to accomodate the lower springs.
Any ideas or suggestions would be greatly appreciated.
Other than the clunking, the car feels great. Its my commuter(75miles/day) and i merely installed the springs to replace the worn stockers. The ride is extremely nice and not too harsh. I still have to play with the adjusters and see what setting i like the best.
Dave
Old May 23, 2010
Re: New suspension installed...Question
did you recheck the bolts and nutsw after the install?
If yes and no issues found, try to see the top mounts? I had to change them after installing my KYB AGX.
Besides that, could be sway bar endlinks.
Old May 24, 2010
I changed the top mounts and sway bar end links. Can anything go together improperly? Can the springs be upside down?
Dave
Old May 24, 2010
Dave
strut bearings = strut mounts... Duh! for me... Let's see if somebody else will chime in.
Old May 24, 2010
Cool, no prob.
The ball joints are in good shape. I'm not sure if the lower control arm bushings could be bad, or if its merely the fact that their is no rubber lower spring perch.
Dave
Old Jun 5, 2010
mahout's Avatar
mahout is an unknown quantity at this point
Dave
Often they are result of not bedding the springs against the lower stops. Make sure you twist the springs tight against those stops before tightening the sprin upper seat.
Old Jun 5, 2010
Thanks Mahout, that sounds like what would be causing my issues. I still have to take it apart. I ordered a Civic Haynes repair book....its that bad. Hahaha
On a side note, the springs settled big time. What started off as a 1.25-1.3" drop turned into closer to 1.5"-1.6"". It's still manageable with my stock rims and tires, but i think it would be a little bumpy for my commuter if i put on some thin side-walled 17" or 18" tires.
Dave
Old Jun 9, 2010
speeeedddddfrea's Avatar
speeeedddddfrea is an unknown quantity at this point
totally true
Old Oct 6, 2010
I have a feeling you are correct,. Nothing up front looks loose or worn that would clunk.
Dave
Tedverseti
Apr 23, 2020 01:45 PM
Mad Dog Tannen
Oct 19, 2016 08:12 PM
Tedverseti
Sep 29, 2015 05:41 PM
czarlun
Sep 14, 2015 08:16 PM
Mad Dog Tannen
Sep 12, 2015 12:48 AM
