confused on which koni yellows i need.
Old Feb 27, 2010
Pongo08's Avatar
Pongo08 is an unknown quantity at this point
ok so i went to tire rack and selected my car, then went to the suspension parts page. when i got to the koni yellows there were two choices for the front struts, ones for cars with 53.8mm outer diameter front struts, and one for 50.5mm. anybody know which ones i need? '01 EX coupe.
Old Apr 28, 2010
o0oWunCivic's Avatar
o0oWunCivic is an unknown quantity at this point
Re: confused on which koni yellows i need.
Its been stickeyed in All The Suspension Info You Need!! Please Read!!! It reads "You've got 2 sizes for koni yellows. 50mm and 55 mm. There is no way of determining which you need by year. You MUST measure the housings of the struts in your car and buy the right ones. Honda mixed them in randomly and there is no other way to tell which ones you need." by robbclark1
Old Jun 12, 2010
SiG's Avatar
SiG
From what I know from when I was running a group-buy years ago on koni yellows, a 2001 requires the smaller size, 50MM. somewhere in 2003 they began using the 55MM but I would check myself if I were you.
Worst case scenario is you get the smaller ones and drill the hole bigger!
Tedverseti
Apr 23, 2020 01:45 PM
JetsterDajet
52
May 8, 2016 12:11 AM
Tedverseti
Sep 29, 2015 05:41 PM
beanhead
Sep 24, 2015 12:04 PM
MamaBear2015
Sep 4, 2015 09:04 PM
