Strut install ....now popping noise!!
Old Mar 22, 2008
alscrx's Avatar
alscrx is an unknown quantity at this point
i changed my front struts with new oem struts and new oem bearing seats. I did mark the spring with the strut housing before removal to make sure they went back the same.....now i get a popping noise after installing.
So i removed them again and check the index marks. The arrows are dead center and pointing out! The spring is seated nice and not rubbing the perch!
what else could it be making that noise????
Old Mar 22, 2008
fallout's Avatar
fallout is a jewel in the roughfallout is a jewel in the roughfallout is a jewel in the roughfallout is a jewel in the rough
Re: Strut install ....now popping noise!!
It's the tension between metal parts rubbing against each other. You need to buy some all purpose grease for suspension and grease them between the springs and the mount. If it helps, looks at the old springs and struts, and grease them where ever the old parts are greased at.
Old Mar 25, 2008
alscrx's Avatar
Are the arrows supposed to point towards each other?
Old Mar 25, 2008
ONE7thREBUILT's Avatar
ONE7thREBUILT has a spectacular aura aboutONE7thREBUILT has a spectacular aura about
Does the popping happen mostly/only while turning or mostly/only on bumps?
Old Mar 25, 2008
alscrx's Avatar
I noticed it on both..Since its a 2002 i have 2 arrows on each strut assembly!
I lined up the arrow on the top hat and on the spring seat like this
If the rim is on the left should they line up like this
Or like so
Old Mar 31, 2008
Mr_Plenty's Avatar
Mr_Plenty is a jewel in the roughMr_Plenty is a jewel in the roughMr_Plenty is a jewel in the rough
hmmm not sure about this one...try the greasing method
Old Mar 31, 2008
greeen01civic4d's Avatar
all arrows should point the same direction
Old Mar 31, 2008
civiccontend34's Avatar
civiccontend34 has a spectacular aura aboutciviccontend34 has a spectacular aura aboutciviccontend34 has a spectacular aura about
hey i installed tein flex last summer and everything was fine and dandy until like a month ago and i got the sam ething, when im turning usually right there is a popping noise everyone once in awhile and only while turning, im hoping its this greasing thing but where do i grease a set of coilovers a bit worried?
Old Mar 31, 2008
fallout's Avatar
I went through the same thing for more than a year. I finally had it and bought some grease. The noise is completely gone. Handling is much smoother and better overall. Grease anywhere metal parts comes in contact with each other. I greased in between spring and bearing and between bearing and top mount.
Old Mar 31, 2008
qnzlilshotta's Avatar
qnzlilshotta is an unknown quantity at this point
i had the same problem with my nuespeed sports n stock struts..came to install my new tokico struts and found out the other guy put the springs in the wrong way...installed my new struts and springs and new bearings and bammm no popping sound
Old Apr 2, 2008
alscrx's Avatar
So how did you align your arrows???
I did the new bearing also and still that damm noise... I have the first arrow pointing towards the car and the second arrow towards outside.....Is this correct?
Old Apr 2, 2008
F**k the arrows. The arrows your talking about are meant for correct torque on a stock (and by stock I mean installed at the factory) suspension. Otherwise it should be different. Torque on a removed bolt means nothing (the arrows on a removed bolt). Its to the point that the arrows don't mean a damn thing. With that much of an open tolerance (vs stock) it means NOTHING!!
Old Apr 3, 2008
alscrx's Avatar
The arrows on the spring seat and top hat are meant for alignment!!
I don't know what your talking about.......
Old Apr 3, 2008
Allignment when all components are stock installed at the factory.
Old Apr 3, 2008
alscrx's Avatar
So why does everyone get this noise then if the arrow marks don't matter??
Old Apr 3, 2008
dont listen, the arrows do matter, the arrow is on the top hat, dont listen to someone who hasnt done this, listen to me, and listen well, the arrows all point towards outside of vehicle, it matters when they springs seat in the top hat, please, redo that part, all the arrows should line op with each other, facing outwards
Old Apr 3, 2008
Dont listen to me....do whatever you want.
Old Apr 3, 2008
alscrx's Avatar
Finally a real answer!!!!!!!!!
I had the arrow tips touching eachother....so thats the noise problem...... So the arrows need to be facing the rim.....Gotta try this ASAP!
This will be my third time removing the strut assemblies trying to solve this problem! Hopefully this works!
Old Apr 3, 2008
while ur in there, grease the top hats, and the bearings, itll save u some more time
Old Jul 2, 2008
alscrx's Avatar
OK, i redid the strut assembly because the driver side was making noise after i did the new oem front struts. Passenger side is fine!!
So i aligned the arows up the way its supposed to be. I greased the top of the spring where it looks like it may touch. I have brand new bearings i bought. I reinstalled and still a little bit of popping noise. What the hell could it be. How could the driver side be so picky with alighnment but passenger side is perfect???
Does the top hat go bad?
Could it be a bad coil spring?
Old Jul 2, 2008
Yes and yes to your questions. Metal springs with dirt (or less than complete lubrication) and weight on them are quite sticky, making them 'pop' while twisting them during turning.
Problems like this one have a way of moving about without any real signs until they become a problem.
Old Jul 3, 2008
beadebaserr's Avatar
beadebaserr will become famous soon enoughbeadebaserr will become famous soon enough
i dont even have an arrow on my drivers side spring seat (aftermarket). it's easy to tell how it's supposed to go in there just by looking at the shape of the strut tower, not to mention the top hat mount has a specific bolt pattern that will only go through the holes one way.
GolNat
Suspension DIY
May 12, 2022 06:49 AM
Nalmonte
Suspension
Jun 9, 2015 07:08 PM
reqy
Jun 1, 2015 07:05 AM
edgenet
May 2, 2015 08:00 PM
Thees1
Apr 14, 2015 08:23 AM
