Hi, quick question
Old Nov 3, 2007
dafynesplaya's Avatar
dafynesplaya is an unknown quantity at this point
Smile Hi, quick question
Hi, I was sick of bumpy ride(stock shock+eibach lowering springs) and just installed the tein basic coilover. I thought I dropped the same height front and rear but rear seems way lower than the front. Is it normal? What's the best way to adjust it evenly? Also, I didn't do the alignment yet cuz lotta thread says it changes again after a week or so.... how do I deal with the alignment then? Is there any more stuff that I need to keep in mind after installing them?? Thank you!!
Old Nov 3, 2007
greeen01civic4d's Avatar
Re: Hi, quick question
u have a sedan or coupe?
Old Nov 3, 2007
i have a coupe
Old Nov 3, 2007
FGCOUPE's Avatar
FGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to all
did you make sure to install the springs right side up?
on my prokit, there were numbers on the coils, these had to be rightside up and depending left or right side
Old Nov 3, 2007
its because stock shocks in the rear on the coupe are longer than the fronts, and even though u used drop springs, the rear sits higher, with coilovers, to avoid rear sag u have to adjust them slightly higher than the front to get a higher rear end(seems obvious), its just the way the coupes sit, dont ask me why, but coilovers are designed to level out the cord
Old Nov 3, 2007
FGCOUPE's Avatar
well i know even on my 06 civic, after the Prokit was installed correctly there still is a slight rake on the rear, this is why im thinking on Tein 1.5" for the rears and keep my 1" Prokit up front.
Old Nov 3, 2007
hmm....so it seems to be normal...
i guess i have to adjust the rear one bit higher...
thnx so much guys!!
Old Nov 3, 2007
yup thats the whole good thing about the setup. you can adjust them to be even on both ends. just have them bring the rear up a bit.
Old Nov 3, 2007
FGCOUPE's Avatar
adjust the rear springs how exactly?
on my 06 i dont think theres any adjustments that can be made except buying a different spring thats either highr/lower?
Old Nov 3, 2007
Envy's Avatar
Diamond Member
Envy is a glorious beacon of lightEnvy is a glorious beacon of lightEnvy is a glorious beacon of lightEnvy is a glorious beacon of lightEnvy is a glorious beacon of light
you have springs. hes talking adjusting coilovers
Old Nov 3, 2007
ya lol. and idk, my prokit is even drop all around on my sedan (w/new tokico shocks ofcourse).
Old Nov 3, 2007
FGCOUPE's Avatar
ahhh...sory, i thought it was just springs! lol
Old Nov 3, 2007
well you can adjust springs too! just take them off and cut some of the coils. thats what my ricer friend told me when i first got my car. ha
Old Nov 3, 2007
robbclark1's Avatar
Retired suspension supermod.
You can cut dead coils on some aftermarket springs to lower them
noobs.
Old Nov 3, 2007
FGCOUPE's Avatar
imho....i wouldnt be cutting any coils up!
they are a certain length for a good reason, by removing even 1 coil will throw the entire spring rate off.
Old Nov 3, 2007
hence the term ricer bounce lmao. yea we all know, it was a joke. noobs, dont go cutting your springs.
Old Nov 3, 2007
FGCOUPE's Avatar
i wasnt sure about you guys.....pheeew! (Fgcoupe wipes his forehead) lmao!
yea....DO NOT cut the coils nor use them Crappytire spring clamps to lower your car people!
Old Nov 3, 2007
robbclark1's Avatar
I'm serious...you can cut dead coils on some aftermarket springs. Coils use linear springs so there are no dead coils. But often aftermarket springs have dead coils that don't do anything. Neuspeed actually recommends it on some of their applications.
Old Nov 3, 2007
sl33pyriceboi's Avatar
hahahhaha. cutting spings....hahah that costed me a car...
i totalled my show car cuz i was that stupid....ooooo what a good hard lesson.
anyways adjusting coils, just measure your wheel wall to the top of ur rim....and know the legnth of that and have it all round.
Old Nov 3, 2007
i think i read a thread sayin you should not be driving much after the coilover installation...is it ture??? i have to drive my car everyday since i go to school everyday......hmm........someone?
Old Nov 3, 2007
AmbulanceMonkee's Avatar
you shouldn't be driving long distances without a proper alignment, it will eat your tires. a quick daily commute should be fine.
Old Nov 3, 2007
foxracingn28's Avatar
foxracingn28 is an unknown quantity at this point
i agree with FGCOUPE on that one.. that could be a very bug mistake
CraigW
Aug 18, 2015 07:06 AM
civic98?
Aug 13, 2015 01:32 AM
Strycker
Aug 2, 2015 08:40 PM
sam31444
ECU Fried
Jul 20, 2015 08:31 AM
NoobyKid
Jul 13, 2015 07:53 AM
