konis squeeking, need some input
Old Jul 26, 2007
Dark_Pyro7's Avatar
Dark_Pyro7 is an unknown quantity at this point
I have an 03 coupe ex. So I am lowered on Koni yellows and goldline. I had a shop do the install so I am not to familier with the workings of it all. I've been lowerd on this setup for about a year and a half. Have had a slight squeek for about half a year, and when I took it in for an alignment the squeek has gotten pretty bad. Sitting still if I even turn the wheel left and right it creeks pretty badly. Mainly just from the passenger front side. I think I may up heard the driverside acting up a bit.
I absolutly hate the noise. If someone could give me an idea of what to check or what I need to do to fix it I would be very greatful.
THanks in advance.
Old Jul 26, 2007
HondaKorn's Avatar
Life is better with 5lug
Re: konis squeeking, need some input
my konis squeek in the rear....
Old Jul 26, 2007
LT2004ever's Avatar
I wil fix vBPlaza today
uh oh a konis problem....
Old Jul 26, 2007
Zzyzx's Avatar
Autocross Junky
It may have nothing to do with your dampers. 1st thing to check is if the spring is seated properly in its perch. after that i'd check to see if there is any play in the tie rod end. Then I'd check to see if the bottom bolt on the konis is tight (mine came loose once in four+ years). and finally I'd check to see if the main strut bearing is still good.
Old Jul 26, 2007
beadebaserr's Avatar
beadebaserr will become famous soon enoughbeadebaserr will become famous soon enough
yeeep. my konis squeak too, but they're almost 100,000 miles old. i think i'm just gonna put some blues and my sportlines back on the car. i dont adjust my suspension anyway.
Old Jul 26, 2007
Dark_Pyro7's Avatar
Awesome that was what I was hoping for. I will have to check it out.
Tedverseti
Apr 23, 2020 01:45 PM
Tedverseti
Sep 29, 2015 05:41 PM
Luluharp
Sep 27, 2015 11:56 AM
speedlever
Sep 24, 2015 07:18 PM
beanhead
Sep 24, 2015 12:04 PM
