Help Koni Yellows
Old Apr 3, 2007
thisaintgino's Avatar
thisaintgino is an unknown quantity at this point
Help Koni Yellows
i got the koni yellows from truehonda about 2 weeks ago for my 2003 coupe civic. they sent it as a straight strut. there is nothing on the front shocks to put it on like a place to connect it to the strut bolts and everything the strut looks like a yellow pole. i was looking around the box for instructions and it says that i need to take off the welded parts off my oem strut and switch it on it the konis.
i was talking to truehonda on AIM and they were telling me that i have to cut my oem struts and use the parts onto the koni.
i have never heard about this ever before. i was asking truehonda some more questions on AIM. and he said they only did this to the 01-05 civics due to new macpherson strut design. he was telling me something about inserts but i didnt really find my answer to my problems.
if you heard of a problem like this please feel free to explain what my best choices are thanks.
Old Apr 3, 2007
Zzyzx's Avatar
Autocross Junky
Re: Help Koni Yellows
Insert type damper replacements are pretty common with strut type suspensions.
Try here for your install info
I run konis and the install only took a few hours with the right equipment. just be sure to measure twice and cut once, just like in wood shop.
Old Apr 3, 2007
thanks for the info. i thot i had wrong parts shipped to me. but yeah thanks for the diy helped alot thanks
Old Apr 8, 2007
Ashhole's Avatar
Ashho-san 7thgen Ninja
Ashhole will become famous soon enoughAshhole will become famous soon enough
wow after reading that DIY and already messin up my sprin install, im gonna pay to have my konis installed
Old Apr 11, 2007
04civic07's Avatar
Living Life Turn After Turn
04civic07 will become famous soon enough04civic07 will become famous soon enough
when cutting the top of the strut off... i suggest going to harbor freight and getting a large pipe cutter, except i went to homedepot to get mine, but it's probably cheaper and better at harbor. probably about $20 and easier than using a hack saw.
Tedverseti
Apr 23, 2020 01:45 PM
jammer48
Oct 4, 2018 10:04 PM
Tedverseti
Sep 29, 2015 05:41 PM
beanhead
Sep 24, 2015 12:04 PM
MamaBear2015
Sep 4, 2015 09:04 PM
