fyi-rear suspension squeak
Old Sep 7, 2007
  #31
greeen01civic4d's Avatar
Re: fyi-rear suspension squeak
its not grease, its PB blaster penetrating oil
http://www.google.com/products?q=pb+...oogle&ct=title
Old Sep 7, 2007
  #32
kcari, what ur experiencing may be the tsb for the rear suspension squeak, which i though i had too, i have the tsb in a pdf file if u want it, just pm me ur email and i can send it to u, including part numbers and stuff
Old Sep 7, 2007
  #33
ryox82's Avatar
ryox82 is a name known to allryox82 is a name known to allryox82 is a name known to allryox82 is a name known to allryox82 is a name known to allryox82 is a name known to allryox82 is a name known to all
Does your alignment shop sell tires too? lol. I just put on one of my SPC rear camber kits on ( ran out of daylight) an I see this beefy bushing on it where it bolts to the body. On the stock arm...I see NOTHING filling in the sides and some crumbling thin hard thing I think used to be rubber...wonder if having that would contribute my rear kicking to and fro over bumps.
Old Sep 7, 2007
  #34
pics!!!, but from the description, id say probably
Old Sep 7, 2007
  #35
ryox82's Avatar
I went to take pictures but I left my USB cable at my job apparently. Doh!! lemme try and take one and send it to my email then ill grab it and post the comparison
Old Sep 7, 2007
  #36
works for me, i did that a few days ago, then remembered my memory card slides into the side of my computer
Old Sep 7, 2007
  #37
ryox82's Avatar
lol I just emailed this to my job and remote desktoped into the office to do this. Left is stock, right is my new SPC camber kit.
Old Sep 7, 2007
  #38
alex.w *//'s Avatar
alex.w *// will become famous soon enough
Originally Posted by rice4lyfe
beware not to use oil-based grease, it will swell up and cause the bushings to deteriorate. Good fix though
isnt pb blaster oil-based grease?
Old Sep 7, 2007
  #39
yes, it IS only a TEMPORARY fix, just keeps from driving u nuts
Old Sep 7, 2007
  #40
alex.w *//'s Avatar
whats a permanant fix for this?...drill a hole for a grease nipple?
Old Sep 7, 2007
  #41
yea, that could contribute, but the oem doesnt seem to be tooo bad, its dry rotted and cracked from what i can tell, rubber sucks, spc comes with polyurethane which is much sturdier and long lasting, i bought ingalls, which can come with either, and im having to replace them after only a year(only a 90 day warranty), but short answer, replace them and see if it goes away, if its crumbling and cracking, then yes, that was ur problem(i know, obvious right) bad bushings suck
Old Sep 7, 2007
  #42
ryox82's Avatar
I hope that was the cause myself. Thanks for givin your opinion!
Old Sep 7, 2007
  #43
anytime ryox, im no expert, but ive been there, done that, good luck
alex w, i would not drill a grease fitting there since its a control arm and there is quite a bit of torque on it during cornering and strut compression, so i would advise against it, pretty much ur only permanent fix is to get an spc with polyurethane bushings
Old Sep 7, 2007
  #44
slowwhitecivic's Avatar
slowwhitecivic will become famous soon enough
the funny thing is i have the same thing happening right now..it just started to squeak in the rear but too lazy to lubricate it. lol its been driving me crazy hearing it lol
Old Sep 7, 2007
  #45
slowwhitecivic, what kinda camber kit u have??
Old Sep 8, 2007
  #46
kcari's Avatar
okay so i went to two shops today and one shop says the squeeking is normal and another shop says bushing issues but the second shop said they'd have to remove my tires, whole suspensionto take a look and that costs a lot of money, so i said forget it. plus i just got an alignment... again... and dont want three alignments in one month...
so i have no idea what to do...
Old Sep 8, 2007
  #47
check ur inbox kcari
Old Dec 12, 2007
  #48
pnoyster2k1cvic's Avatar
Balut Eating Champ
a-haa!!! so thats where these damn squeeks are coming from... good stuff, i will do this tomorrow...
Old Dec 13, 2007
  #49
alex.w *//'s Avatar
hmm the weird thing is i got the squeak when i was on s techs, to fix that i added lubricant to the camber kit joints, and it was gone. now im on coilovers, the squeak is gone
Old Dec 20, 2007
  #50
kcari's Avatar
hey just to update you guys... so i took my car to a shop and the guy drove my car around and through speedbumps really hard and fast and the noise was gone. Then flash forward a couple of months to this morning, and I drove into a business center with a pretty steep hill at a weird angle, harder than usual, and the noise came back... so its possible that it could be my dust collector or top thing, i don't have a camber kit so....
but i should get coil overs sometime in january...
seeya
Old Dec 20, 2007
  #51
Maverick_1337's Avatar
Maverick_1337 will become famous soon enoughMaverick_1337 will become famous soon enough
rear brake light noise!!!! damn i hated that http://www.geocities.com/pfeifferper...ightrattle.pdf
Old Dec 20, 2007
  #52
kronickz's Avatar
kronickz is an unknown quantity at this point
yep, when i first installed my ground controls it did this around the bump stop. I just took WD-40 and sprayed it as far up the spring as I could and it stopped.
Tedverseti
Apr 23, 2020 01:45 PM
Mad Dog Tannen
Oct 19, 2016 08:12 PM
Tedverseti
Sep 29, 2015 05:41 PM
czarlun
Sep 14, 2015 08:16 PM
Mad Dog Tannen
Sep 12, 2015 12:48 AM
