what camber kit should i get?
Old Dec 23, 2006
Tokoyama's Avatar
Tokoyama is an unknown quantity at this point
im gonna be lowering my car pretty soon, im going with the tien s-techs, i just dont know what kind of camber kit i should get. what do you guys think? i drive an 05 Sedan DX
Old Dec 23, 2006
johnbt23's Avatar
either ingalls or spc. they are pretty good companies and make good products
Old Dec 23, 2006
mypetstork's Avatar
mypetstork is an unknown quantity at this point
i like spc
Old Dec 24, 2006
navysooner's Avatar
navysooner will become famous soon enoughnavysooner will become famous soon enough
Here's a little advice since its your pfirst post. Post in the right forum!
Old Dec 24, 2006
BiggyQ's Avatar
BiggyQ is an unknown quantity at this point
I got a set of spc. really good camber kit
Old Dec 24, 2006
RHCP0801's Avatar
spc, search
Old Dec 31, 2006
dezod's Avatar
7thgen Power Maker
Ingalls is good for the price especially!
Dezod Motorsports. Camber Kits
Old Jan 1, 2007
Anotherslo1's Avatar
Anotherslo1 is an unknown quantity at this point
Agreed!
Old Jan 1, 2007
Starwin21's Avatar
Starwin21 is an unknown quantity at this point
I don't have a preference b/c I haven't bought my camber kit yet, but you don't necessarily have to have it for the front. The guys at my local honda dealer have those aligned perfectly, it's the rear you'll definately want for two reasons; 1) you'll be rocking 2-degrees negative camber in the rear once your springs settle and you have alignment done with your stock suspension, this is rough b/c of excessive inside tire wear, you'll need to rotate your tires every time you change your oil to keep things from getting too bad. 2) I travel interstate atleast 100 miles every other weekend between school and home and me and every one of my friends will attest to the car seeking out the lines in the road much more than normal and this could be prevented with a neutral setup, I mention the highway b/c it's pretty exagerated at 80mph. I know Eibach has a kit and if I wasn't going to throw down for coilovers I figure that's who I'd go with, simply b/c of reputation for dependability. Just a little fyi, but I'm starting to like the ingalls too.
Old Jan 2, 2007
eye_see_you's Avatar
let the devil out
I've had both SPC and ingalls and had a problem with the SPC coming apart on the rear now i've switched to ingalls and all my problems were solved
Old Jan 3, 2007
se7engen_riDe's Avatar
se7engen_riDe is an unknown quantity at this point
^^^ well thanks for mentioning that one. i was about to go with a spc camber kit. i guess i'll be going for ingalls....and so should the other guy.
Old Jan 3, 2007
dezod's Avatar
7thgen Power Maker
Yeah I have used Ingalls on a few of my cars in the past. Perfect fitment and adjustment to get the job done!
Old Jan 3, 2007
mr.rowdy's Avatar
mr.rowdy is an unknown quantity at this point
Ingalls
Old Jan 5, 2007
Diablo's Avatar
Diablo is an unknown quantity at this point
The bushings on the SPC rear camberkit dont last long.
Old Jan 7, 2007
zonk's Avatar
zonk is an unknown quantity at this point
i have used ingalls and skunk 2, personally couldnt tell the difference, but had a harder time reinstalling the ball joints on the ingalls
Old Jan 10, 2007
Nameless's Avatar
TURTLEonK
Nameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the rough
Ingalls FTW!
Old Jan 20, 2007
01civichfp's Avatar
01civichfp is an unknown quantity at this point
ok question... i was just researching, and it looks like ingalls is the best for the price.
SO! im lookin here on ebay and it says it'll fit both an RSX & my 01 civic? how's that? isnt the suspension different?
Old Jan 23, 2007
adishman's Avatar
adishman should not be trustedadishman should not be trustedadishman should not be trusted
some parts are the same...
Old Jan 23, 2007
LilWannabeJdm's Avatar
LilWannabeJdm can only hope to improve
Ingalls FTW!!!!!
Old May 31, 2007
sound_bwoy's Avatar
sound_bwoy is an unknown quantity at this point
Re: what camber kit should i get?
So are you saying that after the springs settle, the camber in the front would not be affected, therfore a camber kit for the front would not be necessary?
Old Jun 15, 2007
sound_bwoy's Avatar
I've been looking into some coilover such as the megans and Ksports and the description says that you can adjust the camber on them. Does this mean that they come with a camber kit? If not, is the mechanism in the coil over that lets you adjust the camber better than a seperate camber kit such as ingalls or spc?
Dave Brabant
20
Oct 6, 2015 12:44 AM
Tedverseti
Sep 29, 2015 05:41 PM
Hutch1051
Sep 29, 2015 09:20 AM
anubis62
Sep 27, 2015 12:56 AM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
