tein s tech on 01 2dr
Old Jun 15, 2007
rpk01's Avatar
rpk01 is an unknown quantity at this point
Just looking for a little help on how to fit the assembly back in. If anyone has done this please help me out.
Old Jun 15, 2007
metalviper's Avatar
metalviper is just really nicemetalviper is just really nicemetalviper is just really nicemetalviper is just really nice
Re: tein s tech on 01 2dr
SEARCH!!
https://www.civicforums.com/forums/4...info-pics.html
Old Jun 15, 2007
rpk01's Avatar
Once you put on your new springs, just follow these directions in reverse. You may need to compress the spring in order to put that 17mm bolt back on the top of the strut assembly, unless you have 4 strong hands. If you are installing coilovers, make sure you use the factory bearing ring! Without it you will get nasty clanging noises every time you turn. On the 2001 models, it's a plastic piece with grease on it, on the 2002-2003 models it will be a metal ring attached to the spring cap. Careful when prying it off the cap or you'll open it up and release the ball bearings inside.
I used the diy, but the part above doesn't tell me someones personal experience with these springs. I've looked through the thread and several people mention skunk2 install requires cutting which isn't in the diy. Just looking for help not a troll.
Old Jun 15, 2007
metalviper's Avatar
u mean cutting the bump stops? it should say how much is needed to cut in the papers that came with the springs which u dont actually need to do depending on the drop. other than that there isnt anything u need to cut if you are just installing springs
Old Jun 15, 2007
rpk01's Avatar
Backs are already in. The front is pretty damn far from meeting up and i don't want to pull too hard on the control arm to get the assembly in place. For the backs i had to have someone stand on the drum to fit the assembly in.
Old Jun 15, 2007
LT2004ever's Avatar
I wil fix vBPlaza today
Originally Posted by metalviper
couldn't have said it better myself
Old Jun 15, 2007
Mr_Plenty's Avatar
Mr_Plenty is a jewel in the roughMr_Plenty is a jewel in the roughMr_Plenty is a jewel in the rough
follow the diy and you'll be fine
Old Jun 15, 2007
metalviper's Avatar
is this a 7thgen? cuz the fronts are discs. y dont u just use a jack to lift the disc assembly?
Old Jun 16, 2007
rpk01's Avatar
Had to unhook the strut bar to get the disc to drop down. That wasn't in the DIY and you can't use common sense when you don't know what you are doing. SEARCH failed me this time sorry.
GolNat
Nov 27, 2018 03:32 PM
2002ExCivic
22
Sep 28, 2015 08:29 AM
TheRiddicles
Sep 21, 2015 03:43 PM
TheRiddicles
Sep 21, 2015 01:28 AM
powman02
Sep 15, 2015 07:38 PM
