rear upper strut bar
Old Oct 24, 2006
don007's Avatar
don007 is an unknown quantity at this point
Question rear upper strut bar
I have a 03 civic and do not have info. on how to install the rear bar, can anybody help? Thanks
Old Oct 25, 2006
06CivicHybrid's Avatar
06CivicHybrid is an unknown quantity at this point
if your struts are visible from the trunk , then all you have to do is keep it leveled, apply the emergency brake and take off the rear bolts holding the struts to the car, then slide the Strut bar on top, and re-install the bolts holding it.
If your struts are not visible you need to remove the lower part of the rear seat first (usually by unsnapping the front half then sliding out the rear section), then the back part (unbolt the bottom and top if any, otherwise slide up and out). Once removed do the same as the first paragraph and you should be good to go.
Write back if you have any problems. Please make sure the bolts are on and tighten down correctly. i am giving you directions that i know by experience.
I can't be held responsible or liable for any accidents. its my advice to you. kool?
Old Oct 26, 2006
don007's Avatar
Wink Thanks
You are the man Thanks alot I was able to do the job.
Old Oct 27, 2006
cool, glad i could be of help
trellex
Electrical
Jul 9, 2015 12:01 PM
Causemo
Jul 4, 2015 07:11 AM
0100010
Bolt-on Engine Performance
Nov 26, 2001 07:50 PM
PlatnumBomb
Nov 9, 2001 01:11 PM
