Bump Stops
Old Oct 24, 2006
FoSho's Avatar
FoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of lightFoSho is a glorious beacon of light
Bump Stops
I have an 02 Ex with full B+G coilovers, the bump stops for the front are worn out and loose on the strut shaft/piston. Do I need to contact B+G to get these parts or can I just cut down the stock bump stops?
Old Oct 25, 2006
04civic07's Avatar
Living Life Turn After Turn
04civic07 will become famous soon enough04civic07 will become famous soon enough
honestly, it really shouldn't matter too much. as long as they are there it's alright, loose or tight, should serve the purpose just the same. as long as there is something there to keep the struts from bottoming out.
Old Oct 25, 2006
burke420's Avatar
The World Is Yours!
same as he said, at least there is somethingthere, if it was gone, replace it!but frayed and worn away very bad, look into replacing it...imo
Old Oct 28, 2006
thw_goalie's Avatar
thw_goalie is an unknown quantity at this point
As long as they're not falling off or damaged they should be fine. When your shock compresses it will still hit the bump stop, so it doesn't matter if it's loose or not.
SimpleUser
Apr 24, 2021 02:54 AM
mrohitredd
40
Sep 9, 2017 12:03 PM
DerbyDad03
Jul 27, 2015 11:34 AM
liagreenhalgh92
Jul 21, 2015 01:31 PM
mokkush
Jul 14, 2015 04:05 PM
