strut question
Old Nov 18, 2006
greeen01civic4d's Avatar
strut question
this may sound like a stupid question, but what is the part called that is on top of the strut that holds the bearings, and has the bolts on it that stick through the body of the car??? also, when purchasing aftermarket struts, do they come with this part???
Old Nov 18, 2006
thanks, just hoping my bearings dont all come out when i pull the old ones out, im getting some popping and squeaking, hoping replacing them will help, the squeaking is driving me nuts...
Old Nov 18, 2006
tuningmycivic's Avatar
tuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to all
white lithium grease and bearing grease are your friend.
the spring hat can be reused, the bearing as well, unless you're like me and drop one and it pops open and some of the ball bearings roll down a damn storm drain in the parking lot outside your apartment....but i digress...
Old Nov 18, 2006
sql_civic's Avatar
Are you refering to the strut mount?
Old Nov 18, 2006
SOAD's Avatar
SOAD is on a distinguished road
when i lowered my car that part popped off and i had the bearings roll down my driveway lol, i got all of them and rolled it around in the grease, no squeeks or popping noises at all
it also happened to another civic i lowered, bearings fell out, makes popping noises now but the struts are blown so yea
Old Nov 18, 2006
em2k3's Avatar
em2k3 is an unknown quantity at this point
yeah it's an upper strut mount. when they're bad they vibrate or rattle. i believe that kyb makes some aftermarket ones for like $60
Old Nov 19, 2006
sql_civic's Avatar
Oddly they're a little pricey for not much of a part. They hold up a lot of load though.
Old Nov 29, 2006
well, found out today that it is not the struts at all, but the bushings in the rear knuckle, its a tsb, so i ordered the parts and had em installed today, $200 later squeak gone.... oh well, still gettin adjustables for xmas
Old Nov 29, 2006
TRIZ's Avatar
I was going to say you might want to check your bushings- I have squeeking in the back, my lower control arm bushing is cracked and driving me crazy- yeah the bushing is super cheap compared to the labor.. apparently if you try doing the LCAB yourself you need a blow torch or some rediculous muscle... gosh. I might have to just throw 200 or 300 at honda as well. *sigh* Good luck man.
Oh... getting adjustables huh? I must point you in the direction of the TEIN SS group buy:
http://www.7thgencivic.com/forums/sh...d.php?t=283551
Old Nov 29, 2006
sl33pyriceboi's Avatar
i thought that top strut hat was called a strut pillow mount?
Old Nov 30, 2006
yea, labor was only 135 at a local shop, took about 3 hours using an air chisel, but at long last the squeak is gone, and car is "quiet" again... itll never be quiet in reality... haha
Old Nov 30, 2006
CenZ's Avatar
PWIT
thats my car your talking about. i found out what the popping is, its not my bearings, even though im missing one. its that black thing that sits inside the front strut, its sorta sitting on my spring and getting all sorts of torn up.
Old Nov 30, 2006
SOAD's Avatar
dude your car has been falling apart ever since we lowered it lol, you need those new shocks bad
Sep 26, 2023 06:44 PM
honda.lioness
16
Feb 10, 2017 10:53 PM
Strycker
Aug 2, 2015 08:40 PM
EM_WON
Jul 22, 2015 06:49 PM
NoobyKid
Jul 13, 2015 07:53 AM
