Front and Rear Clunking Noise
Old Aug 10, 2006
  #31
ryangt's Avatar
ryangt is an unknown quantity at this point
yeppers, only when i get the wheel just about hard over to the drivers side tho, then i get a pop
Old Aug 11, 2006
  #32
lewal's Avatar
lewal has a spectacular aura aboutlewal has a spectacular aura aboutlewal has a spectacular aura about
ok, thanks. makes me feel better
Old Aug 12, 2006
  #33
sponjey's Avatar
sponjey is an unknown quantity at this point
sounds like you guys didn't index the struts right when you put them back in if you get a popping noise when turning. are you sure you put the struts back in EXACTLY like they were when you took them out? there's a sticky on this subject, which is not the same as the clunking noise described in this thread.
Old Aug 12, 2006
  #34
NOTORIOUZ's Avatar
NOTORIOUZ is an unknown quantity at this point
wow this thread is still goin on.
DAYUM!!!! well yeh um the clunking is hella annoying isnt it??
ill try to pin point the problems i have had that could possibly lead to the clunking noise on my car.
"the bolt on the bottom of my shock thats holding the koni in could be lose."
"springs arent seated"
"the uppermounts are cracked, torn"
"the springs are hitting against each other"
"Didnt cut enough of the rear bump stop off"
"Not Indexed"
"after market springs are shorter and more coiled then stock springs, Thus the after market springs dont give enough tension and make noise goin over bumps or dips or pot holes"
I really hope this helped people out there with this same problem
Old Aug 14, 2006
  #35
ryangt's Avatar
the noise has persisted for me.
I am a pretty competent person when it comes to this stuff aqnd i had taken my time and indexed the springs and make sure everything was done right, and alligned perfectly, and i still have the noise, i dont know what to tell ya fols, im probably just gonna ditch this koni/ sportline setup, Anyone want them for cheap? Make me an offer.
7thgensurvivor
38
Aug 29, 2015 11:50 AM
SugarRay
Dec 17, 2001 04:17 PM
PimpBot5000
Nov 26, 2001 07:15 PM
andylao
Nov 9, 2001 07:36 PM
JeffSpeed21
Bolt-on Engine Performance
Nov 4, 2001 12:33 PM
