%&$#&$ bolt!
Old Jan 22, 2006
tarheel365's Avatar
tarheel365 is an unknown quantity at this point
%&$#&$ bolt!
i got my blues and i was able to put the front in but when i tried to undo the bolt in the rear it would not budge...
half a can of wd-40 later....still nothing
so i have the blues in the front and stock in the back...
any way i can break the hold of the bolt in the rear?
i really don't wanna take it to a shop cuz the rears are pretty simple to put on.
Old Jan 22, 2006
Boilermaker1's Avatar
Jap-Euro Fusion
WD 40 around rubber bushings isn't a terribly wise idea. Anyways, I assume you mean the bottom one, you need to compress the rear with a jack to get the bolt to release, if its extended its basically being pinned in place by the shock being expanded.
Old Jan 22, 2006
jeffsta17's Avatar
jeffsta17 is an unknown quantity at this point
Just put some muscle into it, I did it like a week ago and it just needs a breaker bar or something...or a 240 lbs guy to pull on it
Old Jan 22, 2006
04|5spdCivic's Avatar
Wish I had a Turbo 3)
04|5spdCivic can only hope to improve
yeah i had a big strong guy climb in my trunk and undo it.
Old Jan 22, 2006
Shifty's Avatar
if you are taking about the bottom bolt holding the shock to the lower control arm, relieve some of the weight off by jacking the control arm up. Then with a FLAT center punch, push it out. It should come off
Old Jan 22, 2006
Shifty's Avatar
exactly, sorry boilermaker, i didnt see your post.
Old Jan 24, 2006
03-Acura-1.7-EL's Avatar
03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light
I did mt spring a while back, I possibly may be wrong, but dont you have to untie a nut, rather bolt??
Old Jan 24, 2006
Ser1N's Avatar
EK Hatch
Ser1N is an unknown quantity at this point
The controll arm bolt, carefull about using a breaker bar. I hear quite a few cases of the seize bolts breaking due to breaker bars. I had to use anti seize spray and a tourqe wrench. (air tools yay! )
Old Jan 24, 2006
tarheel365's Avatar
its the long bolt going through the bottom of the shock.
well i budged it....it budged about 2 mm.
haha i'm gonna put some more liquid wrench and let it soak then give it another try. i'm in no hurry u stupid bolt....ur coming off one way or the other
Old Jan 25, 2006
I just realised, yes its a bolt! lol...
Old Jan 29, 2006
tarheel365's Avatar
ha after about a week and lots of cursing, lots of liquid wrench and skinning of the knuckles...i have triumphed!
i just turned and turned and turned until i heard a bang....and it finally came off. the damn bolt was stuck to the bushings and it would force the bolt back to the original position. so i just maintained the pressure and it finally gave in.
the other side was very easy to take off and hardly needed the use of a breaker bar.
so far the ride feels more rigid but i don't have the bouncing that occurs after big bumps...especially in the rear.
Tedverseti
Sep 29, 2015 05:41 PM
rovafa2002
Sep 28, 2015 06:57 PM
2002ExCivic
22
Sep 28, 2015 08:29 AM
pilebuck13
Sep 21, 2015 10:45 PM
amrhamed
Sep 21, 2015 02:56 PM
