Tein Basics question
Before anyone asks, yes i did search but i didnt find a legitmate answer. Anyways i have Tein Basic coilovers on my coupe and they squeak like hell in the rears. Any ideas on what i can do to fix that? Maybe get some spring isolators? Anyone know where i can find the Tein rubber spring isolators online? Also, my front left suspension pops whenever i turn the steering wheel at low speeds. The suspension was professionally installed by a local tuner shop and worked flawless for about 2 weeks. Then the noises started appearing again. ugh.......im really getting sick of this. Any help is appreciated.
Thanks
Thanks
...and if the lube doesn't work, try cutting the dust covers a little. For mine, I cut about an inch above where it appeared to be rubbing.
On the front, maybe check your bearings? If I remember right its just concentric plastic rings which should rotate smoothly.
BootyDo
Jun 21, 2016 03:45 PM
jzhartman
22
Jul 23, 2015 10:42 PM
Bounddyy
19
Jul 20, 2015 02:42 PM
mokkush
Jul 14, 2015 04:05 PM
NoobyKid
Jul 13, 2015 07:53 AM
