uneven drop
Old Sep 2, 2005
sittinon17s's Avatar
sittinon17s is an unknown quantity at this point
uneven drop
the progress springs i installed said there would be a difference of .2 inches, with more of a drop in the back, but the difference is much more extreme.
In the front there is maybe a half inch gap, but in the back the wheels are tucked a quarter inch! it doesnt look too too bad, hardly even noticeable unless you were looking cause of the shadows. but would this cause any problems? any idea as to why this happened? i messed up putting my new shocks and springs on and for a few days the car's weight was resting entirely on the springs. would this have caused the springs to compact too much?
i also need an alignment reallllly bad, but since the wheel is tucked i cant, so the fenders will have to be rolled. what a pain man, what a pain
Old Sep 2, 2005
puidokas's Avatar
puidokas is an unknown quantity at this point
how is your rear camber
Old Sep 3, 2005
robbclark1's Avatar
Retired suspension supermod.
are you on stock shocks?
Old Sep 3, 2005
SOHC's Avatar
I spent 1425 points to do this.
SOHC is an unknown quantity at this point
ive got your answer...its all about the ground your car's on. very rarely will you ever be parked on a perfectly flat surface. sooo- the weight distrubution of your car will greatly effect the wheel gaps all the way around.
Old Sep 3, 2005
05em2's Avatar
05em2 is an unknown quantity at this point
same problem for me, rear is too low, what can i buy to fix this?
Old Sep 3, 2005
TheSmuggler's Avatar
because fi you look at our car, if you had a perfectly level drop the back would be tucked and the front wouldent. Just the way the car is lol
Old Sep 3, 2005
yeah but no matter what ground im on the rear is always tucked and more of a drop than the front, much more dramatic, even when the front is downhill from the back.
what is camber? i mean i have an idea, and i think that its ridiculous
Old Sep 3, 2005
xDCx's Avatar
xDCx will become famous soon enoughxDCx will become famous soon enough
camber is when the wheels go like this / \ which your wheels are like if they're tucked. u can do a search for pics
i've been riding with an uneven drop for a while on stock shocks (with a system in the trunk) and i havent had any problems.
all our cars are different tho, some cars shocks will blow right away im fortunate enough to be a lucky one i'll be upgrading soon tho.
Old Sep 3, 2005
xDCx's Avatar
but u have new shocks so...u should be good. i hear the springs can take a while to settle in and will probley even out
Old Sep 3, 2005
micks7thgen's Avatar
micks7thgen is an unknown quantity at this point
it is defiantely because they havent broken in yet give it a few days of driving, but the rear wheel well is not the same dimension as the front (smaller) front is bigger because they have to make room for the tire to turn. so the rear will look like it is sitting lower just measure the distance from the ground to the body it should be fairly even at each end.
Old Sep 3, 2005
eye_see_you's Avatar
let the devil out
my rear was the same way when I was riding on stock struts/shocks with my eaibach springs, now with my tokico struts it fixed things
Old Sep 4, 2005
thanks everyone, i haven't been having any problems with it, in fact the ride is a little better than when it was not lowered.
my camber is real bad, the wheels are maybe at a 80 degree angle from the ground.
Tedverseti
Apr 23, 2020 01:45 PM
Tedverseti
Sep 29, 2015 05:41 PM
rovafa2002
Sep 28, 2015 06:57 PM
TheRiddicles
Sep 21, 2015 01:28 AM
Juanb24
Sep 15, 2015 12:39 AM
