noise
Old Aug 17, 2005
slowwhitecivic's Avatar
slowwhitecivic will become famous soon enough
noise
i just install the prokit wit tokico blue for like a week and only when i go down or up a bumb i hear noise from the shocks .. is it normal or something is wrong
Old Aug 17, 2005
02SILVEREX's Avatar
02SILVEREX has a little shameless behaviour in the past
I don't know.... What kind of noise, what does it sound like? When does it happen, bumps, or cornering? Is it only in the front, or the rear? Maby I'll be able to help you after that.... maby....
Old Aug 17, 2005
robbclark1's Avatar
Retired suspension supermod.
yeah what 02silverex said...
Old Aug 17, 2005
well when i go down ramp or go over speedbumb.. it make a thumpin sound and only the front one
Old Aug 17, 2005
streetglower's Avatar
did you index the front struts properly?
Old Aug 17, 2005
wut u mean
Old Aug 17, 2005
Boilermaker1's Avatar
Jap-Euro Fusion
wut u mean
Exactly. Now speak english and read directions.
There's 2 marks on the struts. One is an arrow on the top hat and the other is a painted line on the spring seat. Before you transfered everything to the new strut you should have marked the new spring seat in the same place so the arrow lined up with it and your spring seated properly. You need to take it out now and index them so the ends of the coils sit properly. Then the noise should go away. Right now your springs are not flat on the seats. Refer to step 19 in the DIY.
If that doesn't fix it, then you have a loose nut somewhere in the front suspension. Since you're taking them all out again, make sure they're torqued to spec.
nirvanaguy
25
Oct 26, 2017 07:26 PM
fvckbg
Sep 8, 2015 09:55 PM
Josh 1973
Sep 7, 2015 10:10 AM
junkyardguy
20
Sep 6, 2015 10:07 PM
tommycanada
Sep 5, 2015 04:59 PM
