should I worry.
Old Aug 12, 2005
04rscivic's Avatar
04rscivic is an unknown quantity at this point
Question should I worry.
I just got some ground controls on my vic, and I hear a noise coming from the rear left side suspension everytime I break. Should I worry about this? or is it that I just have to wait until the new springs settle in.
Old Aug 12, 2005
sweeteli99's Avatar
sweeteli99 will become famous soon enoughsweeteli99 will become famous soon enough
what kind of sound is it?
Old Aug 12, 2005
04rscivic's Avatar
its a squeeking sound.
Old Aug 12, 2005
sweeteli99's Avatar
hmm, might be the springs settling still..
Old Aug 12, 2005
04rscivic's Avatar
okay, then i wont worry.
Old Aug 12, 2005
Ryan2005's Avatar
Ryan2005 is an unknown quantity at this point
i have the same ground control kit on my car, never had that problem, but i would worry about it, try jacking that side up and make sure that the spring is in the right position,
did you put it on yourself or get someone to do it for you?
Old Aug 12, 2005
Boilermaker1's Avatar
Jap-Euro Fusion
There is no "right position"
Its a racing spring, it has 2 flat ends.
The spring won't make noise unless its rubbing on something. So its either rubbing the collar because its not centered, or the poly seat on top of it is making noise.
I'd bet on the latter... especially if you didn't trim the molding flash off of it before you installed it. if it fits tight in the upper hat, I almost guarantee thats your noise.
Moving to suspension....
Old Aug 13, 2005
Zerohnine's Avatar
Zerohnine is an unknown quantity at this point
it's probably rubbing. i had the same problem with my gc's. when i bought mine, which was when they first came out, they came with a urethane bushing that sits above the spring. with the compression, the spring rubbed against the urethan bushing and created a squeaking sound. i believe the new gc's come with a plastic replacement that should eliminate the sound.
Pangaea
Aug 24, 2014 11:01 AM
linton23
Sep 11, 2013 06:33 PM
Gunner
Suspension DIY
Sep 9, 2012 09:11 AM
Fate
Mar 27, 2012 03:16 PM
BrillianceLin
General DIY
Oct 23, 2011 08:57 PM
