front camber is 14 mm cambolt?
Old Aug 6, 2005
peimp's Avatar
peimp is an unknown quantity at this point
thats what they guys said i would need to adjust the camber in the front of my 02 lx cpe. two 14 mm cambolts you can buy from napa or something. can someone verify? im going to get car aligigned on tuesday.
Old Aug 6, 2005
tony_buttons's Avatar
I'm unusually bored.
tony_buttons is an unknown quantity at this point
yeah the front camber is aligned with a new set of bolts strangely enough. You can get them for like 20 bucks. It might vary in size depending on model year... I think 01-02 and 03-05 are diff. even though when I ordered mine (goldline) all it said was 01-up civic, I haven't had any problems, and I have an 03.
Old Aug 6, 2005
peimp's Avatar
sweet thanks bro
Old Aug 7, 2005
robbclark1's Avatar
Retired suspension supermod.
Tony, If it isn't tight enough, your camber can change and can even "fall out" if you hit a bump.
Old Aug 7, 2005
just a quick thread jacking...I thought ^that was possible, but I haven't seen any change since they were installed...either way if I were to get replacements, are the si and rsx bolts the same size as the 03-up civic?
Old Aug 7, 2005
robbclark1's Avatar
I am confused. I did you reuse your stock bolts or get an aftermarket camber kit? SPC has 03+ front camber kits. You can just reuse your stock bolts but you won't get any camber adjustment out of them.
Old Aug 7, 2005
peimp's Avatar
the guys at belle tire said all i needed to adjust the front camber was 2 14mm cambolts that i could get from napa auto. is that true rob?
Old Aug 7, 2005
robbclark1's Avatar
I dunno if you can get cam bolts at napa. Get the SPC set and yes you will need 14mm ones.
Old Aug 7, 2005
jttegx's Avatar
OMNES AD UNUM
front camber wear shouldnt be an issue on the 01+ civic (excl. 02+si). you can slam 3" and front wheels wouldnt have camber wear
Old Aug 8, 2005
robbclark1's Avatar
some people like the adjustability and the ability to run more negative camber...-2 degrees baby
Old Aug 8, 2005
oh, I meant aftermarket ... I have what they said was for an 01-up civic by goldline, I was just wondering if I should replace them with 03-up specific. And by the way when I got my wheels and tires and dropped them without the front camber bolts, the front tires wore out on the inside in less than 8k. I know that hankook ventus aren't the best, but still... the back ones are still rolling with most of the tread left. It matters, you cant be buying tires every year.
Old Aug 8, 2005
robbclark1's Avatar
I would replace them, but you will have to get another alignment.
BootyDo
Jun 21, 2016 03:45 PM
Misfit2613
Jul 30, 2015 09:49 AM
jzhartman
22
Jul 23, 2015 10:42 PM
Fred65
Wheels and Tires
Jul 14, 2015 06:40 AM
muttleytm
Jul 11, 2015 06:00 PM
