Progress 22mm W/O Tie....Do I need brackets?
Old Jul 6, 2005
Pharoh's Avatar
Bobaganoosh!
I bought a Progress 22mm rear sway bar but the guy I bought it from wanted to keep the tie bar.
I'm not sure if I can use this without the brackets it came with for use on the tie bar or if the stock brackets will go around the Progress bushings.
anyone know for sure?
Old Jul 6, 2005
robbclark1's Avatar
Retired suspension supermod.
Why did he keep the brackets? He doesn't need the brackets for the tie bar? Unless he got another 22mm bar.
I don't think the stock ones will fit a 22mm bar. But you can try it isn't that hard. Brace the control arm, unscrew a bracket and see it it fits. If not, you will need brackets . You can get OEM Acura ones (DC5R) or you can call progress and get theirs.
Old Jul 6, 2005
Pharoh's Avatar
Bobaganoosh!
I just off the phone with someone at Progress. They said that they can sell me the tie bar and hardware but all they can do is cut the price of the whole rear end kit in half...very $$. She thinks that I will need the U-brackets for it...I actually have the bushings though...lol. Also, she said that she's not sure you can even use another 22mm bar with that tie bar because of the shape...they're designed to go together.
Old Jul 9, 2005
03CivicEX4Door's Avatar
03CivicEX4Door is an unknown quantity at this point
Try and get the hard wear for the guy you bought the sway bar from.
Old Jul 9, 2005
Boilermaker1's Avatar
Jap-Euro Fusion
buy the Energy suspension 7/8" poly bushings and brackets. $14, call it a day.
If you have 22mm rubber or poly inserts that fit the stock brackets (Honda or Comptech sell them), then you can put those in the stock brackets. Otherwise you'll need a bushing and bracket kit.
Old Jul 9, 2005
eyegiant's Avatar
eyegiant is an unknown quantity at this point
it helps to have that tie bar, but you must get it for him, I mean the whole rear bar comes with that.
Old Jul 9, 2005
should have gotten the neuspeed
Old Jul 9, 2005
injencivic's Avatar
injencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of light
i took the progress sway bar off and left the silver metal piece on with stock bushings, but i did put back my oem sway on...
Now i am trying to figure out how to keep my tcs2 from hitting the progress sway.
Injen
Old Jul 12, 2005
you're not gaining any thing by keeping progress metal peice with stock sway bar.
Old Jul 13, 2005
TeLLy's Avatar
Yes, it's an Acura EL
Energy Suspension makes 22mm polyurethane bushings that come with the brackets. I have them on my DC5R bar.
I imagine since you're losing a little bit of spacing between the subframe and the bushings (ie the thickness of the progress tie bar) you may be able to offset that difference by taking a set of height-adjustable endlinks (Grey's) and rotate the bar a little. There shouldn't be any loss in performance on the sway bar. Oh, but you may knock the control arms a little if you're really low.
Old Jul 13, 2005
Pharoh's Avatar
Bobaganoosh!
I have grey's endlinks for the rear also. I'm going to look at Energy Suspension for sure
Bruce2
Sep 27, 2015 08:45 PM
rnaodm
Sep 21, 2015 12:42 PM
krazykoncepts
Sep 8, 2015 09:02 PM
7thgensurvivor
Aug 28, 2015 08:39 PM
mishima
Aug 22, 2015 06:32 PM
