Can Anyone Help Solve This...?
Old Jun 18, 2005
Zerohnine's Avatar
Zerohnine is an unknown quantity at this point
i was trying to lower the front further down and the lock ring is jammed. the threads above and below look fairly okay, but the adjusting lock/ring is stuck and i cannot move it up or down. i tried using a bolt and nut loosener spray and that didnt help. i even tried using a hammer to see if it would move, and nope, didnt move.
any suggestions on what i should do? i want to move it back up, but i wont move.
Old Jun 18, 2005
Boilermaker1's Avatar
Jap-Euro Fusion
What kind?
Were the threads clean before you started moving them? If they weren't and you caught something underneath, you're effectively locking it in place because a pebble will just dig into those aluminum rings. Check the threads and make sure they're clear of debris and also not flat spotted. If you couldn't advance the ring with a hammer, you're either locking it tighter (going the wrong way), or something really has it jammed. I used to loctite collars in place and I could always break that (150 lb-ft) with a few taps from a rubber hammer.
Old Jun 19, 2005
Zerohnine's Avatar
they're b+g's s3, and new. yea, i think they thread may have been dirty or something may have been there that i didnt see, and now it's under the lock ring. either way, it wont move. if i try and move it up, it gets tighter. if i try to move it down, it wont move. suggestions?
Old Jun 19, 2005
Jap-Euro Fusion
Spanner wrench, hammer, hit it in whatever direction it'll move. Work it back and forth if you have to. Eventually its gotta break free. If you're totally screwed, take a dremel and cut off the lockring, you'll have to buy another one, but it'll take it of. Just make sure you don't dremel into the threads. Go most of the way from both sides, then snap the ring in half with a chisel.
nola000
Engine start problems
63
Feb 17, 2023 09:18 PM
senicalj4579
Oct 2, 2015 10:03 AM
Deebo12
Air Conditioning
Sep 26, 2015 11:08 PM
mrohitredd
Aug 12, 2015 11:36 AM
LorenzoC0395
Jul 14, 2015 08:46 PM
