eibach camber kits
Old Jun 12, 2005
xgimmick's Avatar
xgimmick will become famous soon enoughxgimmick will become famous soon enough
eibach camber kits
does anyone know if their kits are good. im assuming they are since eibach is a reputable company but i haven't heard of any 7thgenner having one since most use SPC or Ingalls. Can anyone give me more info on these ?
Here's a link to where i saw them: http://www.prostreetonline.com/buy/e...kits/5.84580k/
thanks
Old Jun 13, 2005
bobsagator's Avatar
bobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of lightbobsagator is a glorious beacon of light
^ curious too
Another question - do the Sportlines come with Eibach's Camber kit? As per TrueHonda's site
"Sportline engineers realized that when you are lowering your car for the extreme, the camber and caster of the car can be adversely affected. Decreasing tire contact patch and effecting tire life and cornering ability. That is why only Sportline offers alignment hardware kits especially for your car. This will remedy the problems of tire wear and limited tire contact patch."
Old Jun 13, 2005
soonercivic's Avatar
soonercivic is a jewel in the roughsoonercivic is a jewel in the roughsoonercivic is a jewel in the roughsoonercivic is a jewel in the rough
i havent heard of anyone using them. If its 90 for all four then its a great price though! And no, sportlines do not come with a camber kit. That just means that in addition to making the springs they offer the alignment kits since they realize you should need one and definetly should get one when lowering your car.
Old Jun 14, 2005
bobsagator's Avatar
Ah I see, just misread it.
Comparing the Eibach to the SPC, the fronts are both for +/- 1.75 but the rears are +6/-4 for SPC and +/- .75 for Eibach. Is this because the SPC are control arm replacements, and therefore more reliable?
Old Jun 14, 2005
LayinLo's Avatar
LayinLo is an unknown quantity at this point
good ??? bob, I have heard its better to get the arms in the front vs. the bolts.
Old Jun 14, 2005
So the range of adjustment for the SPC is greater than the eibach. Which is good if you plan on lowering your car very much. I dont think you have an option for the front, all we can use are the bolts.
Old Jun 14, 2005
etdigitalis's Avatar
etdigitalis should not be trusted
What arm? The front camber is set by two bolts that go through your strut/knuckle. All a front camber kit is, is a slightly skinnier or tapered bolt.
edit: Failure to read the next post. I'm a n00b.
Old Jun 16, 2005
peteriap's Avatar
peteriap will become famous soon enoughpeteriap will become famous soon enough
FYI, SPC is the OEM for the Eibach kits. Therefore, the Eibach kits are identical to the SPC kits because they ARE the SPC kits. Hope this helps.
Old Jun 21, 2005
zambaleno's Avatar
zambaleno is an unknown quantity at this point
so if im getting sportlines with stock shocks the eibach kit will do good?or its better to get the spc kits?
Old Jun 21, 2005
Whichever you can get a better price on. They are both made by SPC.
Dave Brabant
20
Oct 6, 2015 12:44 AM
Tedverseti
Sep 29, 2015 05:41 PM
Hutch1051
Sep 29, 2015 09:20 AM
anubis62
Sep 27, 2015 12:56 AM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
