*updated w/pics* Tein Basics...(problem solved)
Old Apr 16, 2005
  #31
Yoyoio's Avatar
Yoyoio is an unknown quantity at this point
Originally Posted by flyers27
new problem now......just put on the stock roms and tires and lowered the car to 1 1/2 finger gap no more rubbing, but the rear passenger side is clanking over bumps and not the other side. Everything is the same (height, and amount of dust cover that was cut, no added weight in the back or anything) WTF, one problem to the next. Any ideas on what it could be?
make sure the adjustment locks are tight on the coilover... double check everything again.
Old Apr 16, 2005
  #32
flyers27's Avatar
Broad Street Bullies
flyers27 is an unknown quantity at this point
they are tight... i went over them and the camber kit when i relowered my car after i put the stock rims on. i am going to take out the entire assemly tommorow to see what going on, just wondered if anyone experienced this problem. like i said, it just started happening when i lowered the car more after i put the stock rims and tires on. 1 1/2 finger gap. i dont understand....the noise is a loud clanking. SUCKS!!!! i thought these coilovers were supposed to be top of the line and didnt thionk i was going to have any problems. thank god i didnt get it aligned right away.
Old Apr 16, 2005
  #33
Boilermaker1's Avatar
Jap-Euro Fusion
Options:
Shorter tires - Dumb, waste of money, ruins rims
Stiffer Springs - better handling, worse ride, less travel means lower drop possible
Add Camber - puts tire inside fender, doesn't eat tires badly if toe is zeroed
Roll fenders - I hate body work.
215/45/17 can be dropped on pretty far if you do it right. My car sits static at a finger and a half (I don't know what that is in drop inches) on +38mm offset rims with 215/45/17 tires. It never rubbed with -.75 deg. of camber and now it damn sure doesn't rub with -1.6 deg. of camber. I don't understand what all this woo ha is about getting shorter tires. That just lets you lower the car in the wheelwells more, making your steering arm angle worse and making the wheel wells look bigger than they already are but it makes the car shorter overall because the height of the tire drops the car vs a taller tire. My car falls almost .75" when I switch to a 205/50/15 and I don't do anything to the suspension.
Old Apr 16, 2005
  #34
flyers27's Avatar
i already solved the rubbing problem by putting the OEM rims and tires on, then lowered the car to 1 1/2 finger gap and now get a clanking sound over bumps from the passenger rear and not the driver rear.
Old Apr 17, 2005
  #35
Yoyoio's Avatar
i m lowered on basic, 1 finger gap all around and i don't have any sounds.
the perch on my coilover are set to barely preloading the spring. Did you install something wrong on the uppermount?
Old Apr 17, 2005
  #36
franco921's Avatar
franco921 is an unknown quantity at this point
this might help
i had the same problem your exhaust might be touching the control arm cuz its so low well this happen to me but i dont know check it and see if thats the problem
Old Apr 17, 2005
  #37
flyers27's Avatar
exhaust is stock, both sides were put togetther identically so maybeit is the exhaust. IDK. well im going to go take it apart now to try and find out.
Old Apr 17, 2005
  #38
hustlelikem0fo's Avatar
that sound is your dust boot rubbing on the spring when it compresses
Old Apr 17, 2005
  #39
flyers27's Avatar
i cut the end of the dust boot 1 1/2 inches fromt he bottom already.....should i cut more you think?
Old Apr 17, 2005
  #40
Jap-Euro Fusion
Thats not really a solution, thats just avoiding the problem with thinner tires. If you want to run 17s then you still need to solve it. The clanking is probably a loose collar, thats usually what causes noises.
Old Apr 17, 2005
  #41
flyers27's Avatar
ive decided not to go with the 17's. i just want to figure out what the noise is....its probably the dust boot because it doesnt really make the sound unless i hit a hard bump and compresses the shock further than before because the shock is lower now that i changed back to stock rims. its like a thud noise. evrything is tight, i just went over everything today, took it all out and put it back in.....al tight.
Old Apr 19, 2005
  #42
flyers27's Avatar
problem solved.....cut the dust boots and only left about an inch on them and no more noise....thanks guys.
Old Apr 19, 2005
  #43
Vinnie's Avatar
Vinnie should not be trustedVinnie should not be trustedVinnie should not be trustedVinnie should not be trusted
How did you cut the dust boot? Did you totally remove the coilover and then cut the dust boot? Or did you just cut it while it was still installed to your car?
Old Apr 19, 2005
  #44
flyers27's Avatar
the first time i cut i while i was assembling the teins, so it was off the car. the second time i did not want to take the whole thing apart again so i just did it with a steak knife while it was still on the car. little bit of a pain in the neck but still worth n taking the whole unit out again.
MamaBear2015
Jun 11, 2015 07:33 PM
cukaracha
Jun 7, 2015 03:32 PM
reqy
Jun 1, 2015 07:05 AM
elitezdc5
May 26, 2015 05:46 PM
