INstructions for Skunk2 Coilovers
Old Mar 8, 2005
Blackness's Avatar
From: Charlotte, NC, But Greenville, NC for School-ECU
Blackness is an unknown quantity at this point
Lightbulb INstructions for Skunk2 Coilovers
Ok Skunk 2 doesn't like sending instructions with their coilovers. So would anybody happen to know how to install them or could send me some intructions or something. THANKS!
Old Mar 8, 2005
ojay's Avatar
ojay is on a distinguished road
http://www.7thgencivic.com/forums/sh...ad.php?t=86545
pretty much universal and same idea...
Old Mar 8, 2005
Blackness's Avatar
Yeah I saw that already, but I need to know if the shorter one goes on the front or the back. Like I need directions for Skunk2 Coilovers. Thanks
Old Mar 8, 2005
jttegx's Avatar
OMNES AD UNUM
shorter springs go on front. i believe skunk2 only gives u 2 of those top mount metal plates, those go on top of the front shorter springs as well.
front = shorter springs, top mount plates, and perch itself
rear = taller springs and perch itself.
skunk2 drops from .5-3" i think. i had mine fronts so theres 8 threads up front starting from the top & 5 threads on the rears starting from bottom.
expect grinding/rubbing/clanking metal rubbing noise on the fronts. once installed when you steer, your gonna hear metal on metal rubbing type of noise which can disturb you. simple solution is to grease the top mount plates on the fronts, on top of springs, and bottom of springs. DO NOT GREASE THE PERCH AS THEY WILL HAVE AN EVEN EASIER TIME TO MOVE LEFT AND RIGHT THUS CAUSING IT TO ADJUST ITSELF (i had bad expierence )
hope that helps
Tedverseti
Apr 23, 2020 01:45 PM
GolNat
Nov 27, 2018 03:32 PM
Dave Brabant
20
Oct 6, 2015 12:44 AM
Tedverseti
Sep 29, 2015 05:41 PM
beanhead
Sep 24, 2015 12:04 PM
