installing springs and shocks...PROBLEM
Old Mar 6, 2005
UnitZero's Avatar
UnitZero is an unknown quantity at this point
After getting the tein springs onto the tokico shocks, we cant get it back onto the car. Its kinda hard to explain but we cant compress the spring enough to line up the 2 bolts that are on the shocks.
any ideas ?
Old Mar 6, 2005
civicrice's Avatar
civicrice should not be trustedcivicrice should not be trusted
get a long pipe and stick it up in the engine compartment and the other end under the tie rod thing and just rip it up
Old Mar 6, 2005
UnitZero's Avatar
here's a pic of the problem....the strut holes wont line up with the holes on the steering knuckle.
Old Mar 6, 2005
UnitZero's Avatar
its an ex BTW.....we couldn't lower the steering knuckle enough cause of the sway bar i think.
Old Mar 6, 2005
krayziebonet4l's Avatar
Samoan<^>(-_-)<^>Power
krayziebonet4l is an unknown quantity at this point
is the strut secure on the top
Old Mar 6, 2005
^^^make sure the strut is all the way up through the strut tower to give u all the clearance youll need
Old Mar 6, 2005
dirtySAMURAI's Avatar
I log in from time to time
compress the **** out of that strut.
Old Mar 6, 2005
Boilermaker1's Avatar
Jap-Euro Fusion
we had that problem with Konis this weekend. Hold the brake upright so the axle stays in the transmission, and bring it down as far as you can. Then get your buddy to push up on the strut, get it lined up behind the knuckle and push it in. Its a bitch, you might have to put the spring compressor back on and pull the spring up so you can do it, but it will go.... you just gotta muscle it in.
Old Mar 6, 2005
flotsamm's Avatar
You have both side jacked up? If not the swaybar might be holding the side your working on down.
Old Mar 6, 2005
UnitZero's Avatar
thanks, we're sitting on that problem for now.....hope the back aren't as troublesome
Old Mar 6, 2005
edicivic2k1's Avatar
edicivic2k1 is an unknown quantity at this point
i put the wheel on the hub, then put the scissors jack on top of the tire and the top of wheel well and pumped it up a bit. it doesnt take much and one person can get the shocks installed rather safely. better than laying underneath a jacked up car.
good luck.
Old Mar 7, 2005
anibal's Avatar
anibal is an unknown quantity at this point
I didn't have that problem installing front AGX on stock springs yesterday, but had it on the back. You have to use some muscle to make it be aligned, although, in the back i had to use the stock jack to push down the lower arm.
Sep 26, 2023 06:44 PM
mjdiaz89
Jun 21, 2016 09:26 PM
Misfit2613
Jul 30, 2015 09:49 AM
Bill in San Jos
Jul 10, 2015 12:32 PM
Ccoop87
Jul 9, 2015 03:26 PM
