[HELP ME] After putting RSX-s rear Sway bar.....
Hi.
I own 03 Civic EX
Today, I changed my OEM rear sway bar(12mm) to RSX-S sway bar(19mm).
After I change the sway bar, I hear metal hitting sound from the rear suspension area when I turn hard..
My suspension is all stock expect the 19mm rsx-s sway bar.
What do I have to do?
I own 03 Civic EX
Originally Posted by TeLLy
On a stock suspension I don't see how even a wider-diameter exhaust pipe using stock hangers will hit the 19mm bar. I'd say it's installed upside down.
to verify that its your muffler, just get under your car and look at the muffler and the bar, you will see them come together, or they will be about 1/4" apart, thats the problem.
Autocross Junky
it depends on how stiff his springs are... as I was able to get my 19mm bar to press against the exaust both on and off track. the 25.4mm one I have now, doesnt...
Originally Posted by Zzyzx
Two things... its either insalled backwards... or its just hitting your exaust pipe.
Pudnite
May 9, 2015 07:51 PM
oneheadlight
Apr 29, 2015 11:30 PM
