quick question
Old Dec 21, 2004
HITMAN's Avatar
7thgencivic's Official Bad Samaritan
HITMAN has a reputation beyond reputeHITMAN has a reputation beyond reputeHITMAN has a reputation beyond reputeHITMAN has a reputation beyond reputeHITMAN has a reputation beyond reputeHITMAN has a reputation beyond reputeHITMAN has a reputation beyond reputeHITMAN has a reputation beyond reputeHITMAN has a reputation beyond reputeHITMAN has a reputation beyond reputeHITMAN has a reputation beyond repute
quick question
Hey, just wanted to know if the tokico blues for the 01-02's will fit on the 03 EX? Thanks in advance.
Old Dec 21, 2004
nindoo's Avatar
Why is my vagina bleeding?
I think you got to modify them, cubanmike26 got them modded to fit his 04.
This is what I got from Robclark Shocks FAQ
"All shocks, except for konis, are made for a 2001-2002, so the mount bolts are 14mm not 16mm like in the 2003+. Either you will have to drill them out or hope that the company makes a set for you guys. The can be put on your 2003+ but you run the risk of the mount bolts coming loose and the shock changing camber. There is a rumor that tokico has made 2003+ shocks for the blues, but I am not sure yet. "
Old Dec 21, 2004
civicvtec1ps's Avatar
Search and Learn
Just need to enlarge knuckle hole to 16mm from 14mm.
They will fit.
Old Dec 21, 2004
D17thgen's Avatar
D17thgen has a spectacular aura aboutD17thgen has a spectacular aura aboutD17thgen has a spectacular aura about
they COULD fit you mean. just if your willing to risk extending the size of the knuckle holes from 14mm to 16mm, tokico will most likely void your warranty if you do so.
the rears will fit directly with no special modification as so i read from this board.
Old Dec 21, 2004
Xenin's Avatar
Superior Evolutionary Element Destined-factor
Xenin is an unknown quantity at this point
dont they make blues for the RSX which is the same strut/shock for 2003 Civics? i'm not entirely sure on that.
CraigW
Aug 18, 2015 07:06 AM
civic98?
Aug 13, 2015 01:32 AM
Strycker
Aug 2, 2015 08:40 PM
sam31444
ECU Fried
Jul 20, 2015 08:31 AM
NoobyKid
Jul 13, 2015 07:53 AM
