bouncey rear end.......
Old Oct 23, 2004
OMega's Avatar
OMega is an unknown quantity at this point
The other day I was drive to the dealer to change my oil. I've had problems with my car wondering after 50mph. I can feal the rear end wonder around. On the way to the dealer I drove by a semi doing about 75mhp and almost lost control. Felt like somebody kick me in my side. I can see if the semi was driving by me but not the other way around. Everything is stock. The dealer said there's nothing wrong with my rear shocks.
Old Oct 23, 2004
half_n_half17's Avatar
half_n_half17 is an unknown quantity at this point
your allignment could be off... when was the last time you got it alligned?
Old Oct 23, 2004
OMega's Avatar
In August.
Old Oct 24, 2004
Mr.Modify's Avatar
do you got a drop?
Old Oct 24, 2004
Caucasian.Asian's Avatar
if your car swung around only in that one case i would say nothing was wrong with your car. when you go by a big rig you can sometimes catch the air shooting off their truck and it will hit yours, knocking you around. its just because trucks have bad aerodynamics.
the same thing will happen if you follow behind a big rig close enough. when their truck goes from side to side from the wind, yours will follow the same path and go side to side...
Old Oct 24, 2004
jttegx's Avatar
OMNES AD UNUM
what are your suspension and/or wheel mods?
Old Oct 27, 2004
OMega's Avatar
I have no mods. I think I found the problem, I'm too light! Before I put bigger deck speakers in and removed the trunk bar things, I cared my book in the trunk. Lately I've had my stuff in the passenger seat. The other day I put my books in the trunk again...no more floating @ss on the highway.
Old Oct 27, 2004
Zzyzx's Avatar
Autocross Junky
The stock Civic is UnderDampered from the factory, so even though the shocks may not be blown, the car can still be unstable (thanks to it underdampering the car) The reason they do this is to give a Light car a Softer ride. But it comprimises handling a bit.
so, Pick up some tokico Hp's and that should take care of your problem.
Old Nov 7, 2004
manahoonie's Avatar
also could be the tires. when was the last time your tires were rotated??? I keep getting bull **** from our dealer, saying that it doesn't matter how they rotate the tires for non-directional tires, and this past time, they didn't even rotate them at all!!! check your tires OFTEN!!!!
GolNat
Nov 27, 2018 03:32 PM
h4ldol
Apr 24, 2017 08:16 PM
Sep 27, 2015 11:33 AM
speedlever
Sep 24, 2015 07:18 PM
czarlun
Sep 14, 2015 08:16 PM
