I Got Really Bad Front Suspensions
Old Oct 5, 2004
PrYnCeQT's Avatar
PrYnCeQT is an unknown quantity at this point
My 2002 Civic SI why 83k on it now has a really bad front suspension problem. I bounce everytime i hit a pothole, steers to the left when i let go and steering wheel shakes when i go about 120kmph. I really need them replaced or fixed, I'm totally car stupid so I'm not sure if its the suspension or shocks or if they actually are the same thing. How much would OEM ones installed to replace the fronts cost roughly? Should I look at replacing them with aftermarkets, even just the front? How much would a full set to lower my car cost anyways if its not much more? Anything will help me out, thanks a lot.
Old Oct 5, 2004
Zzyzx's Avatar
Autocross Junky
1, sounds like your shocks are blown. (OEM is too expensive for what you get, Pick up some Tokico HP shocks and you'd be golden.)
2. You probably really need an alignment (Do you remember the last time you had one done? If not do so now.)
3. If the steering wheel shakes while going straight, thats ushually a wheel balance thing...
Old Oct 5, 2004
robbclark1's Avatar
Retired suspension supermod.
please read the suspensin FAQ in my sig and listen to zzyzx.
Old Oct 6, 2004
PrYnCeQT's Avatar
yes i absolutely need an alignment long ago but don't have time to do it. will getting an alignment fix my steering wheel also?
how much do those Tokico HP shocks cost installed?
How much would a full set to lower the car a bit cost? if i'm going to fix the shocks might as well try to lower it too.
Old Oct 6, 2004
robbclark1's Avatar
tokico's are about 400-450 and whatever installation will cost you. You, personally, need to pick the springs you want to lower the car. I wouldn't go too low on tokico's. Again, look at the FAQ and search for parts, and look in the review section.
Old Oct 6, 2004
AggressiveAdam's Avatar
AggressiveAdam will become famous soon enoughAggressiveAdam will become famous soon enough
not neccasarily,
if he only has one strut blown he would have to buy two after market ones.
I got honda oem strut installed by my mechanic for $300 cdn,
edspyhill09
Jun 12, 2016 02:45 PM
oneheadlight
Apr 29, 2015 11:30 PM
bsmiley
Apr 27, 2015 01:27 PM
GH04si
Apr 15, 2015 08:13 PM
supercivic01
South
Nov 30, 2001 11:27 AM
