need advice-next suspension upgrade
Old Oct 4, 2004
fuledya's Avatar
Super Member
fuledya is an unknown quantity at this point
I got a Nuespeed front strut bar, and am lowered on full coilovers. I am trying to figure out what to do next, but I want to do it right. I was thinking a Nuespeed lower tie bar, and possibly a rear upper stut bar, but I don't think Nuespeed makes one. Then I see the NEUSPEED REAR SWAY/TIE BAR COMBO, and am thinking maybe I should get that, cause I would hate to get just the tie bar now, and then later want to upgrade the sway bar
Basically, what will give me the greatest handling upgrade, and if you had to do it all over again, what would you have done diff.?
Old Oct 4, 2004
MisterFrankieJ's Avatar
MisterFrankieJ will become famous soon enoughMisterFrankieJ will become famous soon enough
Id go with a rear sway bar. Progress or oem rsx
Old Oct 5, 2004
half_n_half17's Avatar
half_n_half17 is an unknown quantity at this point
agreed.
Old Oct 5, 2004
robbclark1's Avatar
Retired suspension supermod.
sway bars are the best upgrade for you money. A rear under tie bar doesn't do anything for handling. It is a chassis brace. I say get the progress sway bar set or even just a 22mm rear sway bar. What is your stock front? if it is 16mm then get a 19mm RSX rear sway bar.
Tedverseti
Apr 23, 2020 01:45 PM
Cam Diaz
Sep 29, 2015 07:17 PM
Tedverseti
Sep 29, 2015 05:41 PM
czarlun
Sep 14, 2015 08:16 PM
Mad Dog Tannen
Sep 12, 2015 12:48 AM
