Uneven drop?
Old Sep 28, 2004
AnaRki's Avatar
DDC Representa
AnaRki is an unknown quantity at this point
Uneven drop?
Hey, I have some eibach sportlines and the drop is different on each side od my car, i was just wondering if anyone else has this problem? Or what's the cause of it? thx.
Old Sep 28, 2004
Mr.Modify's Avatar
is it slightly noticeable? cause that's normal........
Old Sep 28, 2004
TeLLy's Avatar
Yes, it's an Acura EL
I'm betting the driver's side is lower than the passenger side am I right? It's due to the engine weight being concentrated on that side, as well as YOU sitting on that side more often than a passenger sitting in the seat next to you. It's normal. I never got a chance to check it out but as far as some posts on this board say, the stock front springs are of differing lengths in order to compensate for it. Aftermarket springs are same length though, thus a more noticable difference in drop height. No biggy really. When the springs eventually settle, the difference will be minimized.
Old Sep 28, 2004
JDMPanda's Avatar
JDMPanda is an unknown quantity at this point
yup ^ thats why im getting some coilovers to even both sides out
Old Sep 28, 2004
TSSCivic's Avatar
TSSCivic is an unknown quantity at this point
Yea & the front fender gap is more than the rear.
Old Sep 28, 2004
AnaRki's Avatar
DDC Representa
oh ic. thanks
Old Sep 28, 2004
Civicly02's Avatar
I have that problem. Will stiffer shocks help this problem or am I just screwed
Old Sep 28, 2004
TSSCivic's Avatar
No, it won't but that is not a problem of the car. All Hondas are designed that way for some reason. The front gap is always more than the rear even with factory springs. The only way you can solve this is just by using the coil over kit.
Old Sep 30, 2004
Psychosoul's Avatar
Psychosoul is an unknown quantity at this point
I have the same uneven drop like yours, plus my squeaks too.
Old Oct 2, 2004
SHiRO's Avatar
SHiRO is an unknown quantity at this point
if your front drop is higher than the rear..
just put some spacers on the rear... that should do the job
give the springs some time to settle too
Tedverseti
Apr 23, 2020 01:45 PM
Tedverseti
Sep 29, 2015 05:41 PM
rovafa2002
Sep 28, 2015 06:57 PM
TheRiddicles
Sep 21, 2015 01:28 AM
Juanb24
Sep 15, 2015 12:39 AM
