How many of you dont have a camber kit?
Old Sep 23, 2004
civicrice's Avatar
civicrice should not be trustedcivicrice should not be trusted
and how long have u been riding around like this for? i put in neuspeed sports a few weeks ago and the back wheels are bowed. i was just wondering how long untill my tires ware (15's) or if i should just buy a camber kit. also where can i get one cheep.
Old Sep 23, 2004
i've been goin on without one since may after i put on my tein s-techs and my back tires have noticeable negative camber.. i even took a cross country road trip and i'm still fine.. i've probably driven 6000 miles or so? i'm getting one soon.. jumped on a group buy from truehonda to get a set for 137 shipped..
Old Sep 23, 2004
ZdS03Civic's Avatar
ZdS03Civic is an unknown quantity at this point
Eventually your tires are going to wear out guys. Just save yourself some money and go buy a camber kit. I have the SPC kit and I have no complaints. I got mine from www.truehonda.com for $188 shipped
Old Sep 23, 2004
jackal903's Avatar
jackal903 is an unknown quantity at this point
i got Eibach Sportline spring and 17" rota subzero rims and without camber kit for about 1 year already. that is not i don't want to get the camber kit. because my rims are +45 offset. if i got the camber kit, my rear wheel will rub my fender.....so sad
Old Sep 23, 2004
civicrice's Avatar
yea my brothers rubbed on his integra. you have to cut out part of the quarter panel.
Old Sep 23, 2004
civic01vtec's Avatar
i haven't had one for about 2,000 miles. I am waiting till after winter when i put my summer wheels back on with new tires...........these ones are shot anywayz.
Old Sep 23, 2004
AnaRki's Avatar
DDC Representa
AnaRki is an unknown quantity at this point
Don't camber kits make a little squeakin noise or sometin?
Old Sep 24, 2004
Mr.Modify's Avatar
mine doesn't ...everythings perfect and installed it myself and im no ASE certified mechanic LOL
Old Sep 24, 2004
03civda's Avatar
03civda is an unknown quantity at this point
A buddy of mine just put Eibach ground control coilover and to adjust his camber, he just put 3 washers on to even out the wheels. Works perfect. Cost him $2.
Old Sep 24, 2004
TeLLy's Avatar
Yes, it's an Acura EL
Unless you're dropped over 1.75", I don't see the point in getting a camber kit. A good alignment will be all you need. There WILL be camber wear, but it won't be enough that you'll have to replace your tires significantly sooner. Example - my rear camber has always been off by a couple off degrees in the negative. Yes I do have camber wear in the rear, but you REALLY have to look to see it. There isn't significantly more wear on the inside of the tire than the outside surface there. I have to replace these tires, but it's due to the fronts being worn out from me pushing hard on the corners. The rears are still great.
Old Sep 24, 2004
chicohonda02's Avatar
Since 2002 Baby!
I've been on my sprint springs for about 1.5 months and camber kit isn't all that needed. but I will probably get one.
Old Sep 24, 2004
UPSCALE's Avatar
UPSCALE is an unknown quantity at this point
I am on here looking for a reason to buy a camber kit. My rear wheels on my sedan are aiming i at the tops. I bought Eibach Sportlines for my 2002 LX a year and a half ago, dropped the car nearly two inches. Still running the same 15" stock Enkei rims from Honda and the crappiest Firestone tires ever. I have easily put 40000 KLM's on these and still have what I consider good tread with very little un-even wear on the tires.
Okay here is my concern though... stuck with stock shocks. Front is nice and stiff like it should be and no camber problems at all. Rear of car bounces over bumps and is cambered in. I am swapping my stock rims and crappie tires with a friend for her 17" MTS rims and Nankang? tires... apparently made by Falken? I am worried about wear now being an issue and me looking bling bling with angled rims looking like a dog dragging it's *** across the ground.
I am think of going Koni Yellows for da rear... maybe suck up that snotty bounce. I don't want to spend alot of money but will need a decent camber kit as well. Here is a picture... I am swapping the rims on my car on the left with that of the ones on the right. Does it look like a good trade? And also last night I was feeling under the rear fender and they are lower than the front. There is maybe 1-2 inches now between the tire and wheel well. HOLY!!!
A friend said to measure the circumference of my tire and the other one. If they are close then there should be no prob.
Think I said enough?
Dave Brabant
20
Oct 6, 2015 12:44 AM
Tedverseti
Sep 29, 2015 05:41 PM
Hutch1051
Sep 29, 2015 09:20 AM
anubis62
Sep 27, 2015 12:56 AM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
