RSX Suspension for 04 Ex
I'm The Ballz Of 7th Gen
Rep Power: 0 ![MishBallzEM2 is an unknown quantity at this point](https://www.civicforums.com/forums/images/reputation/reputation_pos.gif)
Hey I have an 04 ex coupe, and I am looking to do some suspension upgrades and I heard that the RSX suspension is compatible with the em2's. Could anyone let me know what would be some good upgrades off of the RSX that would work with our rides. Thanks
Life Begins > 6800rpms
Rep Power: 351 ![blouisgod is a splendid one to behold](https://www.civicforums.com/forums/images/reputation/reputation_pos.gif)
![blouisgod is a splendid one to behold](https://www.civicforums.com/forums/images/reputation/reputation_highpos.gif)
The most common complaint I hear about the RSX is the suspension. Its basically same as ours so I'd invest in some other products. However, the rsx type s or type r rear sway bar is a great, cheap mod.
Why is my vagina bleeding?
Rep Power: 282 ![nindoo has a spectacular aura about](https://www.civicforums.com/forums/images/reputation/reputation_pos.gif)
Would it be cheaper to get tein ss coilovers?
I heard the stock rsx suspension is not so great. Are you planning on swapping the engine of one later on?
Retired suspension supermod.
Rep Power: 389 ![robbclark1 is a splendid one to behold](https://www.civicforums.com/forums/images/reputation/reputation_pos.gif)
![robbclark1 is a splendid one to behold](https://www.civicforums.com/forums/images/reputation/reputation_highpos.gif)
IT is compatible, but the springs are different lengths. It might look weird and it isn't that much of an upgrade.
Rep Power: 430 ![streetglower is a name known to all](https://www.civicforums.com/forums/images/reputation/reputation_pos.gif)
![streetglower is a name known to all](https://www.civicforums.com/forums/images/reputation/reputation_highpos.gif)
Originally Posted by indoyum
So, if I bought a JDM 22mm rear sway bar meant for an RSX, it would fit on an '04 coupe?
Rep Power: 0 ![518 is on a distinguished road](https://www.civicforums.com/forums/images/reputation/reputation_pos.gif)
Let see if I got this right. JDM is 22mm and the Civic is 12mm in diameter. JDM's size is almost twice as the OEM Civic. Which 'could' mean that the OEM Civic bushing will not fit the JDM bar. I dont even think the 12mm's bracket will fit the 22mm JDM ones. RSX has the 19mm and using the stock bracket for a 22mm doesnt look like pushing the limit of the bracket can hold. However, 12mm bracket to 22mm bracket?
Originally Posted by Sickboy
I'll know for sure if I can talk myself into upgrading from my 19mm to the comptech + endlinks. ![Sweet](https://www.civicforums.com/forums/images/smilies/bigok.gif)
Thanks everyone. I guess I'll just invest in some aftermarket suspension upgrades. I was thinking about the Tein Basic Damper Coilover Kit. Anyone have any suggestions? Also any other tips or recommendations for other aftermarket parts/companies? Thanks
PunX
09-23-2015 10:45 PM
