All D2 coilover owners please read
Old Sep 8, 2004
  #31
UrbanImport's Avatar
UrbanImport is an unknown quantity at this point
This should all be resolved soon. The problem was D2 didn't inform us of different spring lengths at first. The replacement springs will be provided and shipped free of charge.
I don't see this being an issue in the future as all communication issues with D2 in regards to spring rates which the coilovers come with has been resolved.
Old Sep 9, 2004
  #32
AzNmiKex215's Avatar
2k1civic.com O. G.
^^^^ That is what i call customer service!!!! He is taking care of his customers directly, even though the mix up was MAINLY due to D2 over in Taiwan. Only reason we have such long waits for things is becuase D2 is on the otherside of the planet.
Old Sep 9, 2004
  #33
Shlomo's Avatar
Shlomo is an unknown quantity at this point
yup, thanks urban
Old Sep 16, 2004
  #34
Shlomo's Avatar
hey, aznmikex, have you heard any news from michael yet?
Old Sep 16, 2004
  #35
2k1civic.com O. G.
quick question. Do you have trouble closing your hood with the adjustment stick and dial in? I find that if I turn the stick all the way soft, it sticks up more then usual, thus not letting the hood close all the way. Now if i turn the stick all the way hard, the stick gets lower and goes into the dial more, almost sitting flushly letting the hood close.
As of right now i just drive with the dials on, but the sticks off. ANyone else have this same problem? Also the rear adjustment sticks seem to be stick really high up, They are not flush with the dial at all. Is this the same for everyone else?
Old Sep 16, 2004
  #36
Decamo's Avatar
Decamo has a little shameless behaviour in the past
Sounds like D2 tried to cheap out and use RSX or EP3 rear springs since they have the same suspension setup but longer springs.
Maybe they tried to streamline their manufacturing and only make one rear spring for all? Or it could just be a sorting error in manufacturing.
Old Sep 16, 2004
  #37
2k1civic.com O. G.
Michael,
The springs will ship out in the morning. The UPS Tracking # is 1ZT2T3420345850986
Sorry for all the trouble!
Old Sep 16, 2004
  #38
Shlomo's Avatar
yeah, my hood would not close all the way either. i left the adjustment stick out in the front but left them in in the back.
Old Sep 21, 2004
  #39
2k1civic.com O. G.
This is what i got in the mail today
The springs were Clearly labeled EP3 Rear. So im sure they are okay to use with the civic.
Im assuming i put it on the shock with the smaller spring on the bottom and the taller spring up top, seperated by the purple metal seperator.
Is this some kind of new design? Is this an improvement? It reminds me of the B&G coilover Dual SPring design. The original D2 rears didn't come with this kind of spring.
*Im SURE these new springs will resolve the height issue that some of us D2 owners had with the rear springs being too tall. These new springs are definitly shorter. I just hope it rides just as good!
ID:	38557   Click image for larger version
Old Sep 21, 2004
  #40
Shlomo's Avatar
yeah, i just go mine today. are you sure that the springs will solve the height issue? it looks like the two springs equal the length of the old springs. by the way, when are you installing them?
Old Sep 21, 2004
  #41
2k1civic.com O. G.
yea im sure, the small helper spring isnt really that strong. It will compress a significant amount. i guess it lessins the preload on the springs?
Old Sep 21, 2004
  #42
matrix311's Avatar
matrix311 is on a distinguished road
I have my D2's installed and i dont have any issues closing my hood at all. If i have them all the way tight or all the way loose, i can still close my hood just fine without anything hitting. I do have a 2004 if that makes any difference.
I dont have any issues with the rears either, i have them slammed pretty good and no height issues at all. I dont hardly even have a finger gap on there. The ride quality on these things are perfect. They ride a lot better than the Hayames did and the biggest thing I like is no oversteer issues with them like the Hayames. So far i'm totally satisfied with this suspension.
Here is a pic of my rear drop. I'm assuming I probably have the correct springs on mine.
-Eric
Old Sep 22, 2004
  #43
2k1civic.com O. G.
where your adjustment sticks of different length? i had 4 sticks 2 of them where slightly shorter then the others. I used the short one for the front. If i turn the sticks all the way hard the **** goes down and sits flush with the dial. The looser i turn it, the higher it starts to stick up. ALmost like when you unscrew something.
Old Sep 22, 2004
  #44
Shlomo's Avatar
so, aznmikex did you install them yet?
Old Sep 22, 2004
  #45
2k1civic.com O. G.
not yet, sometime next week.
Old Sep 22, 2004
  #46
CrazyCakes's Avatar
CrazyCakes is an unknown quantity at this point
are the two springs a better design??? if so i feel a little ripped, i have the 10k springs in the rear and they are almost all the way down but i still have about three fingers gap.
Old Sep 22, 2004
  #47
As far as I'm aware 8k is the only rate D2 has implemented the helper spring on. I don't think there is any advantage to the helper spring.
Old Sep 22, 2004
  #48
matrix311's Avatar
nope, mine were all the same length. if i loosen it all the way (turn it counterclockwise) the thing raises up quite a bit, but i can still close my hood and it wont hit. So maybe I just have 4 shorter ones, not sure. I think my springs are correct to considering the drop on my car is slammed pretty good. I'll post full body pics after this weekend, we have a car meet coming up here in phoenix this weekend. Should be good pics and i'll post them after the meet.
Old Sep 22, 2004
  #49
Shlomo's Avatar
so, to get this straight...the NEW larger of the two springs goes on the bottom, then the purple separator, then the NEW smaller of the two springs?? also, i thought the EP3 springs had a different spring rate than the ES1/EM2??
Old Sep 23, 2004
  #50
2k1civic.com O. G.
can you turn your sticks 6 FULL TIMES?
Old Sep 23, 2004
  #51
VNlilMAN's Avatar
The Standard One
that looks awesome for great service at www.urbanimport.com and for D2...
Yeah the helper spring doesnt really effect the ride height much, It is only really there to keep the spring in place so that it doesnt fall off when you jack up the car.
Old Sep 23, 2004
  #52
2k1civic.com O. G.
That makes absolute sense! haha. Since the 8K spring is short, it wont dangle when the car is jacked up or when the car hits bumps.
Old Sep 28, 2004
  #53
Shlomo's Avatar
so can anyone confirm that these are the correct spring rates? the new springs were labled "EP3 rear"...and EP3 has higher spring rates than EM2/ES1
Old Sep 28, 2004
  #54
2k1civic.com O. G.
slightly higher, maybe by 1k or 2k at the most? it shouldnt really be that big of a difference.
Old Sep 28, 2004
  #55
Shlomo's Avatar
ok, well i guess that will work. Getting them put on saturday!! i'm so exicited
Old Oct 1, 2004
  #56
2k1civic.com O. G.
Yea mines are in now. The height issue is totally fixed. With the locks all the way down. im extremely tucking the rear tires. You cannot see the top half of the tire.
*tip: raise your car to the hieght yuo want it before you put it all back on the car. its hard as **** to turn the lock nuts. I turned the rears up 3 threads each and stopped becuase i was exhuasted.
Old Oct 1, 2004
  #57
Shlomo's Avatar
how does it ride compared to before? same? mine are getting put on tommorow!
Old Oct 2, 2004
  #58
Shlomo's Avatar
well, mine are done...feels the same but looks 10x better!!
Old Oct 3, 2004
  #59
gtracing's Avatar
TeLLy is my daddy
gtracing is an unknown quantity at this point
^it shouldn't feel the same...it'll feel the same just driving normally, but try flying around a corner, u'll notice way better handling...i'm using d2 suspension currently, and i absolutely love them...i just wish they had harder springs
Old Oct 3, 2004
  #60
Shlomo's Avatar
i've had the coilovers on for about a month now and they do feel AWESOME. i meant i just got the correct rear springs on.
beeemerdude
Jul 10, 2015 09:22 PM
ZILLA
Jul 10, 2015 06:05 AM
Hqly2001
General
Jul 8, 2015 04:07 PM
robbie374
Jul 7, 2015 02:56 AM
