help on rear hayames
Old Aug 2, 2004
jttegx's Avatar
OMNES AD UNUM
Exclamation help on rear hayames
hey,
i bought an used set of rear hayames WITHOUT the uppermount and wanted to know what i would need in order to use these with my stock uppermounts, if possible? i dont have a good knowledge of suspension and hope that couple members here did
i tried using the components from my stock uppermount to work these rear hayames but it didnt work because the washer from the OEM strut doesnt fit since the strut pole on the hayame is larger then the OEM. i know theirs others but if anyone can tell me exactly what i need in order to work these rear hayames using my rear stock upper mounts.
i tried using a replacement washer but it just slides right thru the strut pole. i think hayame makes a "specialized" washer to fit onto their strut poles
here are couple pics of the rear hayames for civic 01-03. uppermount-less
if anyone needs spare hayame parts, i got em
thanks for any help
Old Aug 2, 2004
jttegx's Avatar
OMNES AD UNUM
heres a shot of the OEM struts/shocks to compare.
notice the washer/metal shell plate thingy/top nut/size of strut pole
i really need help, i been dealing with this problem for like 2 months now
Old Aug 2, 2004
SlammedBlueEM2's Avatar
All Eyes On Z
I'd call SPW. I don't think it's made to work with the stock uppermount without Hayame parts so you might as well get the Hayame uppermounts. 323-268-8382
Old Aug 2, 2004
jttegx's Avatar
OMNES AD UNUM
i called them eariler today, they said they dont sell just the uppermounts, only by the complete set
Old Aug 3, 2004
jttegx's Avatar
OMNES AD UNUM
anyone?
Old Aug 3, 2004
dacivic's Avatar
dacivic is an unknown quantity at this point
From the look of it, the rear upper mount should work. Give it a try!
Old Aug 3, 2004
jttegx's Avatar
OMNES AD UNUM
^^i tried it before. it didnt work =|
Old Aug 3, 2004
All Eyes On Z
The problem is that the center metal tube in the uppermount (enclosed in rubber) won't go through the strut pole because it's too small for the Hayame strut. That's why the stock washer won't go over it (the hole is the same size as the tube in the uppermount). You need the Hayame washer, uppermount tube, rubber housing, and that VERY small ring.
GolNat
Nov 27, 2018 03:32 PM
h4ldol
Apr 24, 2017 08:16 PM
Sep 27, 2015 11:33 AM
speedlever
Sep 24, 2015 07:18 PM
czarlun
Sep 14, 2015 08:16 PM
