Mine's Bigger....
Old Jul 22, 2004
Zzyzx's Avatar
Autocross Junky
Mine's Bigger....
Well, I finished the install and went for a shake down run. So far every thing seems good. But what did I install??? well nothing more then a Hotchkis 25mm Two point adjustible rear anti-roll bar.
I tell you Hotchkis makes one hell of an anti-roll bar, even with it being 25mm It still clears my exaust (My 19mm would rub on hard right turns). Nice shade of red too.... I havent really pushed it yet, due to this just being street driving, but I'll have a full review of my current suspension setup on monday after this weekends autocross.
This is what I got, though it was throuh Robear Racing
http://www.hotchkistuning.com/cgi-bi...atalogno=22404
The bar is adjustible between +168% & +180% of the 19mm bar that I had on there. Just note that the stock rear bar is 13mm.
Only down side I can see right now is that you have to buy the whole set, Front and rear bars, even though the front bars wont fit my EX (Dont want it any way)
Old Jul 22, 2004
clownprince's Avatar
Ricerus Maximus
Awesome, since I have an 01 sedan would this require the same mounting kit that would be required for the Progress bar?
Old Jul 22, 2004
dacivic's Avatar
dacivic is an unknown quantity at this point
If you don't have any sway bar on your 01 you will need a mounting kit.
Old Jul 22, 2004
tcostello's Avatar
tcostello has a little shameless behaviour in the past
I've been running that whole kit on my wifes 03 Si for about 6months. I love'em, but I think I'm gonna pop an endlink soon!
Old Jul 22, 2004
robbclark1's Avatar
Retired suspension supermod.
If you have an LX or DX then yes, you will need a mounting kit.
Old Jul 22, 2004
Green Civic's Avatar
Why doesnt the front fit? Is it because of the subframe? Do you have any pics of the installed bar? I'd love to get one, but school is the top priority.
Old Jul 22, 2004
Sickboy's Avatar
Sickboy will become famous soon enoughSickboy will become famous soon enough
Because of the different curve around the cat. He likes his 15.9mm bar anyways.
Old Jul 22, 2004
Zzyzx's Avatar
Autocross Junky
Ya, Right now I'm runing the 15.9mm front bar, a 25.4mm rear bar, Eibach sportline springs and Koni shocks. Only thing I'm looking to change in the future is to get some ground controls (Custom spring rate of coures )
Ya know I'm not 100% sure the front bar doesnt fit, the shape is very simmilar to the stock 25.4 mm bar i took out. Who konws, I just know that its WAY too big for autocross.
Old Jul 22, 2004
tcostello's Avatar
It won't fit. Only Si & RSX for now. They said maybe in about 6 months for the Ex Coupe. That was awhile back and he was talking about doing some Ford Focus stuff first.
i know it does'nt fit 'cause I tried the factory Si one on my Ex. Missed it by
........... that much
Old Jul 22, 2004
Zzyzx's Avatar
Autocross Junky
^^ Eh, oh well. Didnt want the front bar any way.
I even called Hotchkis to see if I could just get the 25.4mm rear bar, they said nope, you gotta buy the set.
Old Jul 23, 2004
Grey's Avatar
DIY King
That's a killer rear sway bar. I wonder if your track times will improve with the new setup?
Old Jul 23, 2004
Zzyzx's Avatar
Autocross Junky
Hopefully, As I have a little 89 Si that I need to chase down....
BTW, The endlinks I ordered from you showed up the exact same day as the anti-roll bar..... wierd.
Old Jul 23, 2004
Sickboy's Avatar
Keep an eye on that subframe zz.
it's so big...it's so big
Old Jul 23, 2004
Zzyzx's Avatar
Autocross Junky
Plans are allready in the works for reinforcing it....
Just for fun (Or because I'm sick...)
The stock bar was 13mm, the 19mm bar I replaced that with was 456% stronger then the 13mm bar.... The 25.4mm bar I replaced the 19mm bar with is adjustible to be either 168% or 180% stronger then the 19mm bar... (Thanks to the Hotchkis bar being Hollow, Its lighter then the 19mm bar too)
SO the current bar is 624% or 636% stronger then the origninal 13mm bar..
Well See how this one goes for a while.... I may get the Hotchkis 27mm rear bar (which is 202 to 220% stronger then the 19mm bar)
Old Jul 23, 2004
Sickboy's Avatar
Did you calculate using solid or hollow bars? Man, I would consider stiffer rear springs before going any bigger. Anyways, have a good weekend!
Old Jul 23, 2004
Zzyzx's Avatar
Autocross Junky
Both the 13mm and the 19mm are solid.. the 25.4 is hollow (I got the strength from Hotchkis's site)
heres the formula for calulating strength differences in solid bars..
larger bar diameter^4/smaller bar diameter^4 * 100 = percent change in stiffness.
For a hollow bar you have to claculate the rate based on the Outside diamiter (As if it were solid) then you have to subtract the rate of a hypothetical bar that matches the inside diameter (i.d.) of the space within. To do that, you need to know the wall thickness of the hollow bar.
Old Jul 24, 2004
Sickboy's Avatar
It's been a while, but I thought the 19mm was hollow. That's why I was curious how you got its strength measurement, without cutting it in half. Anyways, the bends, lengths, and materials also affect the strength so I don't know about their measurements. Close enough though.
I'm considering the comptech 22mm bar since it uses poly bushings and yet still hugs the subframe by using stock brackets, giving more exhaust clearance. Using the E.S. bushings/brackets, so probably the Progress or Comptech sway/support combos as well, pushes the bar out and into my exhaust. I'm hesitant to move the exhaust because I might sell the car next year, but I'd really really like a 22mm bar. Decisions decisions.
Old Jul 26, 2004
slowvic's Avatar
slowvic is an unknown quantity at this point
Just a thought. The rtr realtime rsx had 43mm front and rear bars.
Old Jul 27, 2004
Zzyzx's Avatar
Autocross Junky
Ok, boys and girls.......
I love steering with the rear end! I am 100% happy with the 25.4mm bar right now. It did every thing I was hoping it would do.
The car had just enough oversteer to really help out in the sweepers (I actually had problems with the car turning in Too quickly, wich is really a good problem to have) Once I got the hang of it I ended up being .996 Behind a lil 89 Si that is fully preped for the national tour.
All in all, The Hotchkis 25.4mm rear bar would be an excelent choice if you plan on Open track and autocrossing, though it may be too much for the average joe on the street.
Old Aug 2, 2004
trance4mer's Avatar
trance4mer is an unknown quantity at this point
kool..
Old Aug 3, 2004
CrazyCakes's Avatar
CrazyCakes is an unknown quantity at this point
what plans do you have for bracing the subframe??? and just to clarify the bar would totaly snap the stock end links, right???
Old Aug 3, 2004
Zzyzx's Avatar
Autocross Junky
not really, I've calculated out that because the Hotchkis bar is hollow, the 25.4mm bar on its strongest setting is just bairly stronger then what a Solid 22mm bar would be..
Hotchkis 25.4mm adjustible bars equivelent Solid bar MM...
Soft = 21.6mm Firm = 22.1MM
Hotchkis 27mm Adjustible bar Equivelent solid bar mm
Soft = 22.65 Firm = 23.1mm
Basically, I may end up going with the 27mm bar in the long run.... But it really depends if I intend to autocross this car for the coming seasons.... I'm kind of in the market for an 89 Si....
Old Aug 3, 2004
Blue_Honda_Civ's Avatar
I drive a jeep to compensate for my tiny pee pee
Blue_Honda_Civ will become famous soon enoughBlue_Honda_Civ will become famous soon enough
sounds good man keep us posted
gilloz
Regular Maintenance
Oct 1, 2015 11:38 AM
General DIY
Sep 25, 2015 08:02 PM
PunX
Sep 23, 2015 10:45 PM
OptimisticWay
Sep 18, 2015 09:37 PM
Mc7602
Sep 17, 2015 02:01 PM
