Hayame Camber
Old Jul 29, 2004
KalliGarri's Avatar
A.K.A BlackCar --- Not From Califorina!
KalliGarri is on a distinguished road
Hayame Camber
i juss got my Hayames... i kno they dunt go that low from the back.. but it i put it to the lowest... how much can i drive before the camber starts wearing out the tireS? im still saving up for the camber kit but i really want to get the coilovers in without the tires wearing out
Old Jul 29, 2004
TeLLy's Avatar
Yes, it's an Acura EL
I dropped mine on Hayames but I don't really believe in camber kits, regardless of what others say. Really if you get an alignment your tire wear should be minimal, especially since you can't drop low enough on Hayames to give any horrible camber. There will obviously be camber wear, but IMHO not that bad.
My 1-year-old Kumhos (yes I know, I want better tires already) haven't got much camber wear, even after last year's negative-camberama on H&R's. Let's put it this way - I know my front camber was pretty dead on last year, but my rear was really really bad, like >2 degrees. When I got them out this year, I couldn't tell which had been in front and which in the rear until I studied them close for a few minutes, so insignificant was the camber wear. I can probably get the rest of this season and a good third of next year's on them still.
Old Jul 29, 2004
streetglower's Avatar
just get them put on now and then when you get your camber kit, put it on and go get your alignment.
Old Jul 29, 2004
TeLLy's Avatar
Unless your toe is all screwed up (like mine after Hayame install). Had to get an alignment asap the car was barely drivable.
Dave Brabant
20
Oct 6, 2015 12:44 AM
Tedverseti
Sep 29, 2015 05:41 PM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
beanhead
Sep 24, 2015 12:04 PM
TheRiddicles
Sep 21, 2015 01:28 AM
