h&r springs problem
Old Jul 25, 2004
ctv's Avatar
ctv
ctv is an unknown quantity at this point
h&r springs problem
i just installed H & R springs and noticed my rear drivers side is almost an inch lower than the rear pass side. could the spring be bad?
i have done springs swaps on lots of cars and never had a problem, and
the rears on my new civic were pretty easy to do at that.
and ideas?
Old Jul 25, 2004
TeLLy's Avatar
Yes, it's an Acura EL
Wait till they settle before you panic. Mine were like that too, then the passenger side settled quite a bit after. Driver's side is always lower though, cause the weight of the engine favours that side.
Still, an inch difference warrants examination. If you have time, why not take them off and try again?
Old Jul 25, 2004
ctv's Avatar
ctv
hey thanks for the advice
maybe ill wait a little
it does seen correct that side settles first
i live near a highwats and always taking a exit loop
so the dr side get the brunt of the load
i was thinking of putting eiback springs on the rear
so its not so low
the H&R springs seen a little too soft to me
Old Jul 25, 2004
TeLLy's Avatar
You think that's bad, I have a sedan....I put H&R's on and wasn't supposed to...sag city.
Old Jul 25, 2004
ctv's Avatar
ctv
well i double checked the rears in the trunk
the strut bolt on the pass side, the side thats higher
was not tight had 2 threads of turning to do
so now im sure it will get alow as the other side
but i may looses the bolts so the rear sits higher, just a thought.
Old Jul 25, 2004
7Gnoob's Avatar
7Gnoob is an unknown quantity at this point
TeLLy> ar H&R a bad choice for a 2001 sedan? I'm just starting my spring research!
Old Jul 25, 2004
TeLLy's Avatar
Well, they aren't recommended for the EX sedan, but I went ahead and got them. Honestly if I had it to do it over again, I wouldn't get H&R's for a sedan cause while they're pretty good in a coupe (rode in a few with stock shocks and H&R) the rear sag can be too much on a sedan, even if it's NOT an EX. Blew my stock rear shocks pretty quick too.
Old Jul 26, 2004
ctv's Avatar
ctv
I am noticing that sag on my coupe
i think im going to switch to the Eibach Pro kit
they are a much stiffer spring
These H&R's are marginally stiffer than stock and lower the car almost 2"
Old Jul 26, 2004
TeLLy's Avatar
I think they're advertised at a 1.3" drop. My rears were fully tucked, fender about halfway down the 205/40/17 tires. There's no way that was only 1.3", ha ha. Then again, my EL weighs more than even an EX sedan if I'm not mistaken.
reqy
Jun 1, 2015 07:05 AM
vtec_concept
May 24, 2015 10:27 AM
cruisers10
May 12, 2015 10:46 PM
oneheadlight
Apr 29, 2015 11:30 PM
Flatlander
Nov 16, 2001 05:38 PM
